Wow Jungle beat, that is some awesome ram!! :shocked:
TeamGroup Xtreem DDR2 667 @ 675Mhz 5-5-5-15 ` 2.5v
E6600
Gigabyte DS3P
http://img255.imageshack.us/img255/5583/675yx7.jpg
My best run:
http://img138.imageshack.us/img138/6221/4113ld2.jpg
GB P35-DS3P rev1.0 vdrop mod pencil
E2160 :)
2x1GB Super Tallent DDR2 800 @ 1373 @ 5-5-5-15-2T @ 2.4v
Bulgarian Fastest E2160 :) All is water cooled!
I use 2.4v and 5-5-5-15 :) Others are auto :) Ammm tweaks i dont think that there isnt something about tweak :) Just good pair :)
Yes you water cooling ;P
Good Luck :)
Ran another time DC on the P5K WS @ 2.55V:
so:
CPU: E6300
RAM: OCZ Sli Ready Edition PC2-8500 GMH/GKX (?)
Board: P5K WS ; 2.55V
http://www.abload.de/img/660mhz5-5-4-10superpzxy.png
Looks like I've made the cut:
P5B Deluxe, E2140, Crucial Pc5300 On h2o
http://i245.photobucket.com/albums/g...itter/pi32.jpg
If I run single channel (1 stick) I can pass 8 hours of Orthos @ 300x10 1200MHz Mem DDR speed. That takes 1.5125 volts to the proc to get the memory controller to handle it though.
The setting below is also 8 hours Orthos stable (8 is good enough for me) and it also requires 1.5+ volts to the processor (Normally takes 1.3~1.35) to get it stable in dual channel @ 280x10 932MHZ DDR Speed.
Not bad for a AMD Box. The Memory is PC9600 Flex - I've only had 1 day to play with it. So perhaps I can do better with more playing. The limiting factor right now is the lack of CPU volts available. Since I'm running water I can give this little Operton alot of juice - Which it really wants when you start overclocking the onboard memory controller. I can run 1.5625 (Max Vcore for an Asus M2N32 SLI Deluxe Wifi) I temps barely sip @ 60C. Which ain't bad at all considering how much overvolting that is. If I can find a way to volt mod this baby I'm sure I could take a shot at this club :-).
P.S. Does anyone has a good Alpha Timing Table or something that you could post so I can see what the Alpha timings for the Flex 1200 are supposed to be. I don't think my board is detecting them correctly (Especially tRC @ 19!?!) - If anyone could post up a MemSet3.4 or 3. whatever screenie that would be great.
Sorry for hijacking the thread. Congrats to all you who made it.
See Ya,
Jealous AMD-Fanboy
Kidding! About the Fanboy part anyway.. I'm just poor.
http://img519.imageshack.us/img519/2...bdc9bi9.th.jpg
Why does memset say 666mhz and CPUZ only say 466mhz? Usually CPUZ is the standard checking tool, so that I dont understand.
When I am ramping up my frequency I relax tRC to 22, but for 24/7 use i tighten it up to 16.
I also noticed your tRAS is 18, I think thats on the EPP for these things, but I run 15 if I am CAS5 or 12-10 if I am CAS4.
It is micron D9GMH so look around at what other users are doing with they're RAM and try and find some memset shots, it doesn't matter so much if they're Flex or not, it what's on the inside.
@ Saturas - They're GMH, not a bad kit to. Not to expensive either.
CellShock 2x1GB PC8000 on Gigabyte P35-DS4 , 2,45V
all I could make in 30 minutes at work :p:
http://img259.imageshack.us/img259/2...000c4edsc0.jpg
Listen guys, this is barely becoming an achievement anymore so I'll only be accepting 32m from now on. That ok?
sounds good to me! Heres a 652.7MHz run for ya :)
2.42V IIRC Crucial Ballistix PC5300
http://img142.imageshack.us/img142/9...cialhg6.th.jpg
Thanks bud. Just too many results now. :) Updated now. Omw that took FOREVER.
Maximus Formula
Ballistix 8500 1gx2
666.7Mhz 32M Pass 2.29v :D
http://cfs10.blog.daum.net/original/...e=8500New4.jpg
ASUS P5K WS
Ballistix 8000 2x512MB
668Mhz 32M @ 2.20V
http://www.abload.de/img/6672.2vbbb.jpg
And here @ 2.25V @ Prime-Blend-Test:
http://www.abload.de/thumb/6672.2558j.png
Insane ballistiX?
2,20 volts on bios.:clap:
Cellshock PC8000 on Maximus:
http://img.photobucket.com/albums/v292/Viss1/676mhz.jpg
680Mhz Mushkin XP2 9200@2.48v
Only 2.75v for my babies, I don't want to kill them...yet :D
