should be same as p5b deluxe
why is Vanderpool Technology set to Disabled??
isnt VT technolagy good for extra peformance with single core aplications?
To load the AHCI drivers you will need to buy an e-sata to sata cable.
Use the e-sata port on the backplate of the board to boot up into windows, whilst enabling the AHCI option in the bios.
The installation will prompt you for drivers :)
Then, simply swap back onto the ICH9 sata port, with AHCI :)
Worked for me.
What's it mean when programs start causing an error and crash instead of Orthos saying there was an error? I've noticed that happening once in a while as I've been testing some high clocks and trying to pinpoint what the failure point is. Is it the CPU, FSB, or Memory most likely? I usually have CPU-Z open when running Orthos and it has been the one to crash the most. It's strange how Orthos will sit and run for hours but applications, including Orthos will randomly crash once in a while.
I have P5K Deluxe too.
Dont know why but i have problems with 4 satas.
I have ICH9 raid enable. Two of the disks are in raid0 and other two are data disks.
The problem appends sometimes, after a couple reboots and the disk that disappear its always the same, no matter what sata port i chose :(
Can someone help me :confused:
I think to some extent for a lot of people. I mean, some CPUs just have a valid FSB wall, but it appears that for a large group, they were board-limited to an extent and just assumed it was CPU. There is no question that for Quads, your FSB (for MOST people) should see good to substantial improvment with P5K. A few people don't, and those people likely were limited by their CPU rather than their board.
Will a RAID controller in 2nd PCI-e slot drop the first to 8x electrical or will it remain 16x?
The first slot will stay at 16x, at least that what cpuz reports for the speed and I have a HPT 2320 4x card in the 2nd pcie slot which works fine.
If I'm not mistaken the 4x limitation of the 2nd slot is due to the connect speed of the sb to the nb since the 2nd pcie slot is handled through the sb.
Look at what CPU-Z is reading for my memory
http://img339.imageshack.us/img339/5026/untitledxx1.jpg
http://img475.imageshack.us/img475/200/cpuzyp4.jpg
This RAM
http://www.newegg.com/Product/Produc...82E16820148070
Anything wrong?
Anyone having any problems with raid 0 on this board? I installed win xp pro 3 times and when accessing the hard drive by a disk scan or defrag or sometimes just random I get bsod and it says the error was caused by iastor.sys I tried recreating my array and formating and still getting it.
Where's the options for DDR2-533 timing?
Is DDR2-533 RAM speed supported at all FSB speeds?
From the photos and descriptions below I don't see
*any* support for DDR2-533 listed at all.
I'm getting a bit worried since I just bought 4GBy
of DDR2-533 RAM on sale; not the fastest but I was
planning to use it until I could buy 8GBy of the faster
stuff on sale.
EDIT: removed the big quoted part. Thanks above for the info.
...nice to see a report...always looking for the "executive summary" :hehe:
I would imagine AUTO would probably run the memory at 533 at default clock speeds, as soon as you set the fsb the real memory options should appear. I have mine at 400fsb and the memory is running 1:1 at ddr2 800 but the bios didn't actually display it until I set the fsb manually.
hi! do any of you guys here know more info about the ROG version of P35 from Asus? will it support ddr2 or ddr3? I just saw this news from Asus' website btw, this is my first post here!:)
VERY extensive!! Good work... :)
For PC Probe II I closed all of the little temp monitors/volatge monitors. How do I get em back?
Real quick, has anyone done a performance comparison between P35 and 975X? How do they compare clock for clock say both at 400fsb DDR2 800. Whats gonna run faster? I still havent been quite sure in reading about the P35, some say better than 965, some say about the same....
