Haha, sorry... that is obvious. When I set the voltage to anything in bios other than manual and the default settings, I can no longer adjust the voltage with RMCLOCK.
On 800MHz CPU's the 4:5 is not available. The lowest seems to be 3:5.
I have a E4400 and with BSEL mod it would not boot (I guess on AUTO the dividers are 4:4 and the memory was running at 1066).
Without BSEL the maximum for me is 280MHz FSB and memory at 933 (I have some cheap Kingmax DDR800).
Do you really think that new dividers will be added with future BIOSes? They released F2 and nothing changed.
it's definitely possible for them to add them. as to why they aren't right now, it seems strange. maybe they have more important things to worry about, and matx gets kicked to the side again
that said, it's strange bsel manipulation doesn't work on this new breed of boards. i remember changing bsel to 333 and it worked fine with p965-ds3 and later bios (it only posted at 266, but that's better than older bios where it wouldn't even post at all).
4:5 is definitely part of 266 strap since it allows for 667ddr operation at 266.
hopefully, if new bios comes out that allows selection or at least opens things up, you'll be able to run at 333strap and use 1:1 even.
guess time will tell
New bios available for download, contains 1:1 divider: http://tw.giga-byte.com/Support/Moth...ProductID=2534
Now it's clear what mobo I will buy :)
cooool. any input on performance levels?
For me, seems the only advantage left for the Asus is the working S3 sleep/resume support. Wonder if F4a has improved on that but from experience (pls feedback here, guys), GA isn't too good on S3 support all along.
Just wanted to hop in and post my results with this board (sorry no screenies as of yet, I'm at work now...).
I popped an E6420 in to mine w/ the stock Intel cooler and clocked it straight up to 3.2ghz @ 1.32v w/ some $80 G.Skill PC2-6400. Rock solid.
I'm very impressed with this boards capabilities, I'm loving it!!!
@Caligula: Thanks for that link, looks like I know what I will be doing tonight :) MORE CLOCKIN'!
any updates on the fsb800 ram-dividers?
:up: Hi Lads.
Righty....im running an e6320 at 445 x 7 = 3115mhz with crucial value ram (667mhz) it all seems good but i cant find where to set the timings apart from the multipliers.
is there anyway to access the advanced timings on this board.
Cheers
Gordy!
Press Ctrl and F1 or something while you're ini bios
-tam2-
so ctrl & f1 when im in the bios will open other options?
cheers
gordy!
:yepp:
timings unlocked
Ideal lads...
this is my first gigabyte board so i need to learn all these hot key tricks...lol...
anyway.....im in at 460mhz now but not stable...thats down to ram timings i think.....so time to play a bit........
will keep you posted......
all in all...im glad my f-i90hd failed......
Gordy! :up:
I guess this E6420 has a pretty serious FSB wall, it doesn't seem to be stable past around 410-420 FSB and I know this board is capable of more than that.
I'm quite content with 3.2ghz on a stock cooler however, I shall just leave it be!
http://upload.overclock3d.net/get.php?id=3218&view=1
I dont think it is an FSB wall of your CPU. it seems to be a lack of voltage - all C2D should be able to do more , but you need more Vcore and a better cooling. 3.6 GHZ should be possible.
I might have missed this, but has anyone compared OC results on this board with IGP enabled vs. plug-in card utilized?
hi ppl
I choose this board as part of my HTPC :)
I order this list of parts:
E2160
A-DATA DDR2 2*1GB PC6400
to come:
Sapphire HD2400PRO 256MB DDR2
LC-POWER 550W 6550 Green Power v2.0 140mm
Zalman 7000B - Cu
Seagate ST3250410AS 250GB (1 prato)
Gigabyte GA-G33M-DS2R
what do you think about that system ?
thx
PS: sorry about my english
anyone got some news on 800-divider?
what about 800 divider? I imagine most of us won't want to use it.
