Originally Posted by
InTheFlow
You should have a higher voltage at the connector. It is a 12V line so with the +- 5% tolerances factored in you should see between 11.4 - 12.6 V on the +12 V Line. Since it works with the other PS, I think the low voltage is the issue. What voltage reading do you get when you measure the +12V line on the other PS? If the EDM's voltage is between the above values, then it has to be something wrong with your other power supply or the wiring job.
I'd look at the wiring first. How did you re-connect any wires that you previously cut? Did you solder them back together or do it another way? If you soldered them, were the solder connections shiny or dull looking after you were finished?
