http://www.tweaktown.com/news/7193/a...med/index.html
some info
http://www.rage3d.com/board/showpost...postcount=3637
i love that beautifull blue CM Stacker 830.....
OMG! There is like so much pics going on! pRon!
It's so much a shame that Pictures of E600s aren't allowed...
OCZ to reach PC11200, 1400 MHz soon
Bit-tech has info about perhaps the fastest memory modules to date - OCZ's PC11200 modules, running at 1400MHz, rated at 5-6-6 timings with an operating voltage of 2.35V. Even though the timings are loose, the high frequency should make up for the loss in performance.
Bit-tech also spotted new Reaper HPC modules, which are now up to PC9600 or 1200MHz speeds.
http://www.techpowerup.com/img/07-03-16/oczmem1_thm.jpg http://www.techpowerup.com/img/07-03-16/oczmem2_thm.jpg
Source: Bit-tech
http://forums.techpowerup.com/showthread.php?t=27488
and more about the Asus Soundcard
Asus has a sound card in the works
PCI Express has been around for a long time, yet very few add in cards have adapted to this interface - many still use plain old PCI, which has caused many motherboard manufacturers to trade off PCIE slots for PCI slots.
Asus is about to change that, being among the few producing a PCI Express sound card. The ultra high fidelity sound card will have 118dB SNR playback and 115dB SNR recording capabilities. Instead of EAX, the card will support Dolby and DTS technologies. Asus claims that this will be useful, as games for consoles natively support these standards. When being ported to the PC platform, no additional coding will be necessary.
The card incorporates many of the features we have seen before on soundcards from other companies, especially those based around the CMedia Oxygen HD audio processor. The features include Dolby Headphone, Dolby Pro Logic IIx, Dolby Virtual Speaker, Dolby Digtal Live, DTS NEO:PC, DTS:Connect and DTS:Interactive.
However, rather than going down the third party audio chip route, Asus decided to develop its own entirely customised audio processing chip in its own labs and have spec’d out the soundcard with ultra high end OpAMPs, DACs and ADCs. The company even included an EMI shield covering because the internals of a PC case are renowned for being an hive for RFI.
The cards should be available for a similar price as Creative's X-Fi Extreme Gamer cards.
http://www.techpowerup.com/img/07-03...ssound_thm.jpg http://www.techpowerup.com/img/07-03...sound2_thm.jpg http://www.techpowerup.com/img/07-03...sound3_thm.jpg
Source: Bit-tech
http://forums.techpowerup.com/showthread.php?t=27489
regards
Oh snap! :toast:
scythe Ninja with watercooling'??
http://img154.imageshack.us/img154/3...0053876vu9.jpg
Looks like a ninja with 2 barbs just dropped onto the heatpipe caps to me :stick:
Pictures of Laptops/Notebooks:
http://images.gfx.no/283/283028/P3156772.JPG
http://images.gfx.no/283/283043/P3146733.JPG
http://images.gfx.no/283/283032/P3146742.JPG
http://images.gfx.no/283/283033/P3156849.JPG
http://images.gfx.no/283/283040/P3156853.JPG
http://images.gfx.no/283/283039/P3156854.JPG
http://images.gfx.no/283/283041/P3156983.JPG
http://images.gfx.no/283/283037/P3156953.JPG
http://images.gfx.no/283/283029/P3156797.JPG
http://images.gfx.no/283/283046/P3156799.JPG
http://images.gfx.no/283/283031/P3146746.JPG
http://images.gfx.no/283/283030/P3146753.JPG
http://images.gfx.no/283/283027/P3156982.JPG
http://images.gfx.no/283/283035/P3156820.JPG
HIS makes six display setup
http://www.fudzilla.com/images/stori...s_monitors.jpgQuote:
We saw a cool setup, six displays running on Vista, on a rather standard system. HIS demonstrated its PCIe 1X cards and we learned that if you plug two PCIe 1X cards and a single PCIe16X one you can end up with six display support.
The HIS PCIe 1X card is based on X1550 chip and it comes with 256 MHz memory. The card is clocked 550 MHz core and 800 MHz memory and one link dual DVI ready.
If you need more than two displays this might be the cheap way to go and you are only limited by a quantity of PCIe slots.
http://www.fudzilla.com/images/stori.../his_card2.jpg
Source
MSI Quad FX mobo???
I hope DFI make a quad FX board.....
Well...
with WC, I think we are trying to move heat out of the case...
Also, cpus have better performance/heat ratios nowadays.
Third, whoever can afford a ninja can buy a cheap 2×120 rad for just a bit more.
It would be useful for vidcards though, as the vrm area can get quite hot, and
could use some cooling without excessive loss of flow.
Didn't Thermaltake have a water cooled heatsink like that? If I remember right it wasn't all that good.
There was Thermaltake Volcano 4005.
Waterblock needs to cool area closest to core, this doesn't.
Well... I was there today. Some photo's of things that made the difference to me.
I have a pic of one kick-ass Samsung-screen, but I don't know which one it is. I was namely kinda in a rush, I think it was called 225CW.
It was a HDTV by Samsung with 22'' screen, 2ms, 1080p Full HD and it had a Xbox 360 hooked up to it. It looked... awesome! :slobber:
http://img252.imageshack.us/img252/5...2007132.th.jpg
The Samsung 932BF, not my taste though... Also in widescreen (dubbed 932BW).
http://img252.imageshack.us/img252/3...2007133.th.jpg
The Abit IP35 board.
http://img252.imageshack.us/img252/7...2007122.th.jpg
The MSI P35 DDR3 Demo.
http://img252.imageshack.us/img252/1...2007121.th.jpg
The Zalman CNPS-8700.
http://img252.imageshack.us/img252/8...2007123.th.jpg
The Zalman VF-1000, available in Silver, Black and... GOLD! Sorry for the blurry pics, but they didn't like our phone/camera that much...
http://img252.imageshack.us/img252/6...2007124.th.jpg
The Zalman ZMachine GT1000 case, with interchangeable colors of fans. Looks like the Fatal1ty-case with some minor improvements.
http://img252.imageshack.us/img252/9...2007131.th.jpg
The new Coolermaster Centurion with 2x 120mms on top and reversed PSU. It has feet for the air that goes to the PSU fan at the bottom of the case.
http://img252.imageshack.us/img252/8...2007130.th.jpg
The Thermaltake LanBox Lite.
http://img252.imageshack.us/img252/8...2007129.th.jpg
The Logitech G5 V2, it does have some anti-slip BTW.
http://img252.imageshack.us/img252/9...2007126.th.jpg
There was lots more, but these were the most exciting to me.
Also, alot of CPU-coolers with fans with text on it (TT's Blue Orb FX), The CM Cosmos, VGA-Coolers for the R600 (R600 was nowhere to be found!), The Asus XG-Station, The Asus Xonar Sound-cards and the big amounts of P35-based boards. Again I must apologise for the quality and the turned pics, just didn't have the time for it.
Gotta love a Lamborghini Murcie LP640 Conv at the Asus Stand and the external 2kW PSU from some random Chinese company... :D
http://img252.imageshack.us/img252/6...2007127.th.jpg
http://img252.imageshack.us/img252/4...2007125.th.jpg
Cheers... :toast:
It`s just Samsung 226BW with HDTV-tuner :DQuote:
...and a nasty glossy display :slap:
but then again - who makes LCD TVs with a TN panel :confused:
Because I felt bad about my pics in my last post, I wanted to make it up to you guys. So, I scanned 2 folders I got from the Zalman Stand on the VF-1000 and the ZMachine GT1000. Here you go!
http://img364.imageshack.us/img364/3...0001ye8.th.jpg
http://img364.imageshack.us/img364/6...nnentu4.th.jpg
Again, enjoy!
You can take the rest just give me the Lamborgini :D
no, nn step, I will not touch you (right now)
Ryan
engadget cebit coverage
http://resources.vr-zone.com//eventp...r07/17/ac2.jpg
http://resources.vr-zone.com//eventp...r07/17/ac3.jpg
http://resources.vr-zone.com//eventp...r07/17/ac1.jpg
http://resources.vr-zone.com//eventp...r07/17/ac4.jpg
http://resources.vr-zone.com//eventp.../17/hipro1.jpg
http://resources.vr-zone.com//eventp.../17/hipro2.jpg
http://resources.vr-zone.com//eventp.../17/hipro7.jpg
http://resources.vr-zone.com//eventp...sungssdhdd.jpg
http://resources.vr-zone.com//eventp...bridssdhdd.jpg
http://resources.vr-zone.com//eventp...c/IMG_5222.jpg
http://resources.vr-zone.com//eventp...c/IMG_5223.jpg
http://resources.vr-zone.com//eventp...c/IMG_5225.jpg
Wow that centurian with pre-cut holes for a 2x120 mm rad looks great.
Lol...
Hyper 730 Watt - and the text says:
"Certified up to
Geforce 8800GTS"
730 just to drive a single 8800GTS? Is there a new revision I don't know about?
:D
It's Hyper... If it was PC P&C or Enermax rated at 730 W it would be certified for 8800GTX SLi
