Hahaha yes each will have an auxillary oil separating stage that will also remove some heat from that stages refrigerant before it hits the main cascading hx's.
Yes, I`m still working on that unit, but have already few more orders, which I`m doing too.
Ordered methane, I should have it around monday. (1,67kg, pure methane), all stages will be autocascading, hope we will see nice results.
Cant wait to see results with pure methane... c'mon Luke... Ricky is putting up some competition! ;)
Well of course, he's doing a three stager after all. This isn't meant to be a quick job, an easy job, or a simple job.
Right behind you Luke. Hope it is all god fun and not too much hard work
seems to me like a lot of work, and your complicating what is not so complicated :confused:
if you have oil problems just use a good oil sep and you will have your problem solved without any headaches, i suggest the Danfoss OUB1 the version for brazing
autocascading the last stage will take the main advantage of using "normal" stages, that is, being able to hold load at close to 0 psi
also be carefull not to "over do" your high stages, a stage were the HX temp is too low for the refrigerant that is condensing will have very low pressures and that will make it not hold any load
each stage should be design with an objective and with knowned boundaries, refering to the refrigerants that will be used
I`ve got methane :woot:
http://www.teampuss.com/lukexe/methane/PICT1088.jpg
http://www.teampuss.com/lukexe/methane/PICT1089.jpg
:D 1,68kg :)
That's a big bottle to say there is only 1.68Kg in... is that full capacity of the tank? On the other hand, I read somewhere methane is quite a light gas, so that would explain :D.
In this bottle metan have 200bara pressure :O
Yes, there is 200bar pressure. huuugee :D
I've been thinking of building a Auto-cascade tuned for a 1Watt load for a freeze drying system, I'll be watching this closely :)
IIRC Ethylene here in the UK is 300bar :eek: !
Austria...
At 20°C Ethylen has around 70bar... so why should there more pressure??
Critical temperature : 9.5°C
Critical pressure : 50.76 bar
So, at 20°C ethylene can't be liquid any more, because of that the pressure will be much higher.
I didn't know it was as high as 300 bar (4350 psi) though, but you're proably right :p: I didn't check.
UFFF !!! Almost all day I have spent at Xtreme Cascade and that Symphy`s unit...
I finished autocascading, 3rd stage :toast: Now leak testing, will vacuum it over night and charge tomorrow with R1150 + R290 for test.
BTW, I brazed captube to suction line with silver :)
After first fight.
II stage isn`t cold enough for methane, -100C only with third stage working. I will try to cut some captube from that stage and recharge it. On II stage is still 8000btu compressor.
Next, third stage autocascading R290/Methane.
1 bar suction pressure / 16 bar discharge --> -137C on evap.
I will fight with it, but propane is doing wonderfull job :D :D After 3h run no oil freezing :D :D
Sorry to hear that Luke, just maintain contact with your buyers.
