Lapping is the way to go....
5. DON'T EVER TOUCH THE LAPPED SURFACE.
Why?? :eek:
Lapping a cpu IHS doesn't make you xtreme, and the domain name is no basis to do stupid things. If you don't know what you're doing or are not sure, don't do it... the domain is also NOT xtreme-waste-of-money-because-xoqolatl-said-i'd-be-xtreme-if-i-lapped-my-x6800.org
Giving such an answer is what makes you a cool-extremesystems-member.org LMAO :D :D :D :rofl: :slap::lsfight:
Lapping is still the only situation where is see people throw out arbitrary temp changes and no one asks for proof and just takes their word.
Some guys just says "lapped my 6300, temps are down 60 degrees. Im stable at 4.6ghz now with a tuniq." and everybody is mesmerized by his shiny cpu. I do believe that there are some slight gains if your using air cooling but for anything more is a waste of time and pain on the hands.
Agree with first part, but not with second. If your CPU was factory-srewed :slapass: then you do get a sufficient effect by lapping it... mirroring is just a PR stunt ;)
So did anyone finally try to put on a cooler on CPU without using thermal conductor paste or similiar...?
I lingered around lapping a cpu for some time, but after seeing all prons and cons, i decided to just do it. I will first lap an older intel cpu, to get that magic touch and some practice ;)
My E6300 is idle at 44-46, with venting coridor, and stock cooling. On loads it goes up to 55-56, which is unacceptable to me. When I installed the cpu, I didn't watch out for surface flatness, so have to test that one out.
My CPU will be officially pimp-lapped by 100% moi :woot: :explode2:
