Awesome time! :up:
Awesome time! :up:
Lol, yeah i drink coke and pray first before hit OK.....
anyway, i run 1m on 3.6 challenge got 13.890s (beat kunnak by 0.001s) but the available memory wasnt the same.... dont know why.
Excuse my n00bness but what are you guys talking about and why is it important and how do you do it?.....
w00t... Finally got all my rams working together...... But everytime I get closer to Gautam, he keeps pulling away lol.....
http://www3.telus.net/luis99/oc/4gss.JPG
my little quad core made it to equal 10th place huh :)
At default 9x multiplier we have Q6600 @9x443FSB via setFSB :cool:
http://fileshosts.com/intel/Asus/P5K..._validated.png
Now this I consider fast considering Kentsfield quad core B3 stepping is slower than core2 duo B2 stepping for Super Pi!
http://fileshosts.com/intel/Asus/P5K...e_12s578ms.png
wow... thats 4:5 looks strong on P5K... i cant boot @ CL4 with that setting on P5B... Cool
yeah P35 chip works properly with 4:5 ratio as per my testing :)
http://www.xtremesystems.org/forums/...&postcount=122
Heres my E6700, I have only had about an hour with it, but here is what I have got so far. This is using a thermalright 120 extreme. I may be keeping my E6600 over this, I'm not sure yet, have to mess with it more to see if I can get a high enough stable clock, to justify keeping it over the E6600.
nice result with your clock, now push it to 4000mhz
Hey loc.o great ram clock, my fav # :clap: :up:
Very fast dino.
hey coop nice going
try running that quad GT 1:1 with supertight timings......they seem to like that :)
and what maxmem are you using
you also should run 1M for about 10 times on each timings change and record the quickest one........i've been lazy with my run.........just set my previously tight timings and ran for a few times and get 531s and a couple of 516s
my RAM is not stable at those settings so i need to get a mobo with reliable voltage regulation on RAM at feed it 2.6v and really tighten things properly and go sub 12.5 which is possible :)
I still need to use divider after awhile to be able to keep up. I was happy to see 600. It booted up @ 616. I've been busy over at low clock. maxmem 600.
staxm, 13 Final
Checking out 4000Mhz single Super Pi 32M on Asus Commando :)
X6800 @4000Mhz
Asus Commando
Super Pi v1.50 32M
10x400FSB 1:1 400Mhz 4-4-4-4
Super Pi 1M = 12.609s
Super Pi 32M = 12m 51.094s
vs
10x400FSB 2:3 600Mhz 5-5-4-5
Super Pi 1M = 12.531s
Super Pi 32M = 12m 07.984s
http://fileshosts.com/intel/Asus/Com..._validated.png
http://fileshosts.com/intel/Asus/Com...e_12s609ms.png
http://fileshosts.com/intel/Asus/Com...2m51s094ms.png
vs
http://fileshosts.com/intel/Asus/Com...e_12s531ms.png
http://fileshosts.com/intel/Asus/Com...2m07s984ms.png
eva: 43+ sec., wow. Did you try other timings by chance, like 5-4-4-5? Thanks for showing both.
EDIT: nevermind, it was slower. I was so intrigued by what you did with Cas5 I ran some myself. I still think 2-2-2-5 so when I see results like yours I'm always amazed. I have my 6600 in the board now so I could not run 2/3. I did 9x444 with 4/5 and came up with this.
dam just missed out on sub 4ghz with Q6600 B3 ES hehe
@4002.6Mhz at 1.6375v bios set
http://fileshosts.com/intel/Asus/P5K...e_12s531ms.png
@3952Mhz at 1.6375v bios set
http://fileshosts.com/intel/Asus/P5K...2m08s641ms.png
http://fileshosts.com/intel/Asus/P5K..._bandwidth.png
strange on P5B Deluxe same ram can do 5-4-4-4 @600Mhz on Asus Commando with 1001 bios only 5-5-4-x and I thought commando clocked ram better than P5B Deluxe ? :(
Not Top10 but it's my first try with 4MB cache on air (previous was E6700 directly on cascade ;)) - 12.593s with E6750 500x8 1:1 4-4-4-4 on Commando, modded 1333 strap (CPU was going for DI ;) but NB was aircooled all the time so no genuine 1066 strap possible, unfortunately):
http://img510.imageshack.us/img510/4...acjirv0.th.jpg
http://img74.imageshack.us/img74/8305/12547fh5.gif
Mainboard : Gigabyte P35-DQ6 , the first P35 Board in the Top10 :)
Hey I'm just wondering, what OS is best for PI benching? Until now I've been using a stripped XP SP2 but someones telling me 2003 Server is better..? Could someone help me out? :p:
