try the 150 divider, not much performance loss if you're able to crank up the cpu speeds.
What a shame, that's pretty bad RAM, you're gonna have to switch over to another divider or get yourself some better RAM.
Check out the 32M in my sig, this is with Gskill GH at some 3.6V, about average for those sticks.
If he uses a server03 installation he should be able to do sub20 32M without too much problems.Quote:
Originally Posted by Zeus
to bad: windows xp installed....
Should not be a problem with XP too. ;)
but who cares 32M? :D
Maybe the handfull of people that give some attention to (ur) AMD 1M results in this intel dominated time? ;)
I would be very intrested in some 32M runs!
yep whould be nice to see if you can go below 20minQuote:
Originally Posted by funkflix
Me 2.Quote:
32M is the ultimate non 3D benchmark for your CPU/RAM
ok then i will run a 32M asap.... another 3700+ SanDiego WR :)
really amazing cpu!!
congrat's, buy better BH5, like jmax_oc :D
well i have here 2x256mb, they goes till 280mhz@3.7V on SuperPi 1M... but the madness is that they are slower as the 2x512mb (with the same clock, timings & sub-timings)... i need a little bit more of cpu-mhz to crack my time... and then the 150 divider is properly faster with the 2x512mb....
Yeah 2x512mb is faster because of bank interleave.
Try to get some other RAM, most kits being sold dirt cheap nowadays.
Try ebay or something.
Good luck. :toast:
:( i tried now 1.8V... no new WR... this chip don't like high voltage.... and at +3°C the coldbug kills good scores...
Damn i really whould have loved to see you brake the worldrecord..... again :D
the prime record will fall, superpi may be...
Try to up your pci-e frequency, it helped me to gain a bit more stability.
PRIME UPDATE
http://octs.ripping.org/3700_wr/prime_3480.jpg
and once again: http://octs.ripping.org/nana2.gif
PRIME UPDATE
http://octs.ripping.org/3700_wr/prime_3510.jpg
this is getting too much ... :o INSANE chip !
thats scary fast for a a64
Its coldbugged@+3c.Quote:
Originally Posted by TaPaKaH
man if I see those temps.. I think if the coldbug didn't exist, every chip would be doing 4ghz with LN2 lol.
Try 2.00v vCore.
2V isn't going to help, only for screenshots maybe, not for benches, the CPU will get way to hot.
Most A64 CPU's loose stability above ~40 degrees.
