Rig is in my sig. Fresh OS install. MBM 5370 installed with no other plug in's. I'd like to install the ASUS P5B Deluxe fix to display my voltages properly though?? I installled the NV GPU plug in after the core temp deal failed and that worked just fine..... GPU core was 450 as it should have been, GPU memory showed 660mhz opposed to the 1320 that is it.... I figure thats x2 cause its DDR memory.
I just can't get the core temp plug-in to work!
MBM is now uninstalled via add/remove programs... I deleted the MBM5 folder from program files and coretemp from windows/system32/driver folder.
I'm ready to start from scratch one more time.... then I call it quits. What should I install first after MBM5.... P5B Deluxe fix, GPU stuff or your core temps- if all can be done.
