Im having problems getting above 3.2 ghz
I have successfully overclocked my e6600 processor with this motherboard (p5b Deluxe wifi/ap) to 3.2 ghz.
I got this by buying a scythe infinity fan with some artic silver thermal paste. I then did some research (since this is my first overclock) and found these settings for the bios.
Advanced -> JumperFree Conf.:
AI Tuning - Manual
CPU Freq. - 356 (which will give you 3.2 ghz)
DRAM Freq. - AUTO
PCI-E Freq. - 100
PCI Clock - 33.33 MHz
Spread Spectrum - Disabled
Memory Voltage - 2.10V
CPU Vcore - 1.36 (I got lots of conflicting opinions on this option. Some people had it as high as 1.45
(all other settings on this page - Auto)
There are settings for Northbridge voltage and southbridge voltage that I leave to auto.
Advanced -> CPU Conf.:
Modify Ratio - DISABLED
C1E - DISABLED
Max CPUID - Disabled
Vanderpool - Enabled
CPU TM - DISABLED
Execute Disable - DISABLED
PECI - Disabled
I have 2 gigs of pc6400 corsair 5-5-5-12 memory running at auto (5-6-6-18).
I am running steady at these settings. Can anyone tell me what the exact settings are needed for 3.4 and 3.6 Ghz. I had it somewhat steady at 3.5 Ghz by just increasing the cpu freq
and the vcore voltage but always ran into problems rebooting.
I have the e6600, p5b deluxe(with updated bios 711), corsair pc6400, however with set to auto it reads currently at 5-6-6-18. scythe infinity
need help to get 3.4 stable
cpu freq ?
dram freq ?
vcore ?
