P5B have a 0.05V Vdrop + 0.03V under load
so 1.55V = 1.47V or so.
Anyone think a new bios is in order? BTW, I'm at 2.9ghz stable still :)
I can't believe I almost waited so long for a P5NSLI (570 sli intel edition). I read that board can't even o/c past 275, surely not worth getting two nvidia cards or two of any since API specs change so fast (DX10 etc...).
I hope this board isn't dead.
another satisfied user here with the vanilla.
had a hard time to find timings for those last four spd settings.
if i kept those timings @ default 10-10-10-10, orthos would fail after a few seconds, and it wouldn't even run spi 32M.
i finally got it working and i hope this settings can help those having problems.
so if your'e having stability issues try to use this spd settings:
4-4-4-12-4-42-3-10-5-13
some mems can handle tighter timings, but for the most usual, this settings should let you run your mems @ 850/880 with the 2.1vdimm that the board has available.(try to get a vdimm mod for this one in the vmods secction so you can take you D9's chips where they deserve to be)
i´m running my 6400 @ 405 x 8 spi 32M stable. i'll prime later on tonight, cause i'm running on stock cooler and getting 65 celsius during dual spi32M.
http://img428.imageshack.us/img428/1...m405zt5.th.jpg
i plan on getting the CPU lapped & watercooled during next week and i believe i could achieve 3.400 orthos stable.
I'm not sure whether you are using P5B or not.Quote:
Originally Posted by remorema
If you are P5B user, you can try this one.
http://rv.page.cegetel.net.perso.ceg.../MemSet965.zip
It works under window environment and show me all timings.
I hope it ould help.
yep i'm a p5b user.Quote:
Originally Posted by happyhehe
that link is broken, but if you remove the /MemSet965.zip it will take you to the beta version that i'm using.
tkx anyway :toast:
getting mine next week will report . say it the pcb lay-out the same ass the deluxe ? good to know for vmods ;)
different layout.. what cpu you have btw?Quote:
Originally Posted by blind_ripper
i'm moving to the deluxe wifi hopefully i can have it by next week :)
tired of this ugly looking mobo inside my case
lol
Oh sorry...but you are right:) .Quote:
I'm talking about memset 2.2 beta.
Try it and copy those data to bios mem-timings:banana:
ah damn , 2 days and board is here . i have a E6600 and tested on P5W DH 3.4ghz easy 3D ;)Quote:
Originally Posted by caater
say are there mods already for this board ? if so post them up with all links to bios's . thx in advance ;)
What is allowing you to burn so much money just because a board you don't look at anyways is ugly :confused:Quote:
Originally Posted by |SiLA|
I wonder if you would get another car if the engine layout was ugly lol
Wow in Italy the sales tax is pretty high no? Or just the income tax?
Is there a ClockGen for this mobo ?
check out the vmods section, persivore's just released the v-core and vdimm mod.Quote:
check for bios over asus ftp.
tapakah
nope clockgen doesn't work for this mobo yet
only for the deluxe
bein ugly looking mobo is just another reason..i need more voltagesQuote:
Originally Posted by CrappyLuckMan
and anyway i didn't bought this mobo..that's why i'm moving to the deluxe wifi..i'm just testing this p5b for the shop :p: :banana: :D
ps
yes taxes here is high 20%
hey sila what about some v-mods??Quote:
persivore just released v-dimm & v-core :woot:
i'll mod mine tomorow and post some results.
I'm afraid P5B owner will have to wait and "pray" since looking at the ClockGen author mood here -> CPUZ comment about P5B Clock Generator chip :p:Quote:
Originally Posted by TaPaKaH
Is there any other software that allow to change FSB from OS ?
Ai Tune... but you have to restart at every change.. how dumb is this software !Quote:
yep stupid software...Quote:
Originally Posted by Vric
i wish Aibooster could run in this board.
will try vmod on it , btw il give u a check on the beta from clockgen ;) it work on the asus P5W DH here it will work to ;)
got it today .
some oc's , tobad i have to boot at the speed that i not can clock in to windows.
setup :
E6600 week24
asus P5B bios 0309
g.skill hz6400
modded mach2 by jort
bothe vcore and vdimm mod done
mach2 cant handel the temps :(
http://i3.photobucket.com/albums/y90...6600pi4138.jpg
http://i3.photobucket.com/albums/y90...0pi16m4ghz.jpg
more to come
-8°C bios @ 1.7vcore
wow.. nice overclock !
thx m8 , its not the best cpu around but it will do .Quote:
need to see for beter temps ;)
Stock cooling
no mods
http://img157.imageshack.us/img157/3892/3465aaxj9.jpg
