where did you find the 0005 bios,pleaseQuote:
Tis a very nice board. ~AUD600? ouch :slapass:
weird thing about having to flash it from windows, the 0005 bios did the same thing to me, the intel bootrom when flashed from the bios, did not work correctly, flash from windows, and works fine, weird.
You can pick them up under $470 AUDQuote:
Originally Posted by knob
does this board reach the same fsb levels as the p5w64?
I'm still considering one of these as replacement for my p5w dh
where can I find the 0005 bios? Thanks in advance.Quote:
Originally Posted by xgman
Hmm - mine won't go far above 300FSB stable with Kentsfield irrespective of multi. Probably to do with 4 cores, 4GB of ram, 2 video cards, etc
I can make it to windows with mem @ lower divider @ 333FSB, but yeah...really stressing the nb.
You won't get really high FSB with Kentsfield on this board. But you should be able to run at least 350FSB with no problem. The P5B Dlx is the best board for Kentsfield if you want to run 400+ FSB.
Originally Posted by bobov
They won't allow post or share with it for whatever reason, but you can maybe PM the source somehwere in this thread or the other ws-pro thread. I am unable to send it to anyone directly as the promise I had to make to get it.
Ahh, but I need my PCI-X slots and my Crossfire..:PQuote:
Originally Posted by sierra_bound
Is the multi unlocked upwards on these? I've seen a screenshot where cpuz says 6-10 but using the 11x multi, but that was on the P5W64. Any way to do it on the P5WDG2-WS Pro?
No, if you set the multi above your max it defaults to max on bootQuote:
Originally Posted by wwwww
Aslo I really have to boggle at the lock down preventing people from sharing the beta bios. Really dont expect that kind of stuff on XS. It almost seems like Asus is trying to prevent features being enabled on their $300+ board... I mean wtf.
Betas sometimes make a board goes beserk. If you want to run beta (its a good idea to) get a spare bios chip (from Asus) first.Quote:
Originally Posted by mds47
The 0614 bios shows multipliers up to x12. But x11 and x12 don't work. When you boot into Windows, CPU-Z shows x10. I did not try anything newer than 0614.Quote:
Both the P5WDG2 and the P5W64 will give multipliers up to x20 with certain bios versions.
This was done with the P5WDG2. My Kentsfield has been passed on to someone else.
http://img149.imageshack.us/img149/8950/381023rh0.jpg
http://img126.imageshack.us/img126/3...0043400as5.jpg
Asus will probably have an updated bios this week. I'll be on the lookout for it!
Off topic: anyone notice the horrible download rates off Asus's website?
Where it can be unloaded the bios 0614. for the Asus P5WDG2-WS Pro?Quote:
By:)
Sorry for confusion. 0614 is for the P5B Dlx.
Ok.:)Quote:
Thanks.
By;)
New bios 0408
ftp://dlsvr02.asus.com/pub/ASUS/mb/s...S-PRO-0408.zip
Bay:)
I saw P5B dlx in your sigQuote:
Originally Posted by Primoz78
not satisfying you too compared to P5w DH ?
what vcore in bios do you have for 3.7 ghz ?Quote:
3.7 ghz requires about 1.5125 or 1.5250 in the bios...that is not orthos stable...need way higher for that...i do not like the cpu heat issue so i settle for one of the above settings which makes it stable for everyday stuff.
idle temp is around 55-58C
So what is the preferred BIOS now? 0005 or 0408?
And what are the main differences, if any between the 2...
0408 better at FSB scaling, also if it fails boot you don't need to clear cmos.Quote:
Originally Posted by eaa315
