howe much is Vdrop when in bios is set at 1.7V?
I hear 1.7v is ~ 1.67v real. Not bad anyway.
I'm having problems, tried overnight prime at 411 FSB and my computer turned off. 1.8 Vmch, ram happy, CPU has excessive volts, what gives!?!?! Seems anything over 400 FSB gets a BSOD eventually...
I did 420 fsb with an e6300 out of the box but I seem stuck @ 430 fsb, doesn't want to boot past that with the stock cooler and ocz plats.
I got the board yesterday vmod it and its running 411fsb with 1.5V VMCH stable .Quote:
what FSB can you attain using your 6600 on the 64 board?Quote:
Originally Posted by Torphoto
Originally Posted by Spacemaster
1.65V+ will have over voltage protection.
:rolleyes: Hm, i still wonder to get my hands on the pencil Vmch mod........, but huh - have to remove the board and the stock NB cooler. Sooooooo much work:(
:toast:
My new e6600 is still on a fedex truck in florida, don't ask what happened to the last one :-(Quote:
Originally Posted by Ace-a-Rue
:rolleyes: The question is at what voltage.............:flame: :caution:Quote:
Newegg out of stock http://www.newegg.com/Product/Produc...82E16813131047
Price went up $20:(
Ewiz probly has old chipsets...
L611AXXX old...
http://img150.imageshack.us/img150/8...shot009ku0.jpg
3618AXXX new...same as BadAxe2....
http://img291.imageshack.us/img291/8...shot005ok1.jpg
Is there a significant difference between the two, or don't we know yet?
I hope this isn't another P5WDH-like hardware change :(
i need some help with clkgen and cpu-z . im booting 445 straight from biose .and as soon as i up fsb with clkgen the system freezez .no matter whatt fsb. another thing is that cpu-z is only letting me se cpu 1. on the p5w dh i could se the other cpu aswell .my cpu is a 6600 running with 9 multipler .and im using stock biose . any help appriciated .
Use ICS 954123 and disabled C1/EIST in bios.Quote:
Originally Posted by vanovich
Download cpuz/clockgen new versions...http://www.cpuid.com/clockgen.php
Maybe it has been said here but I have a question about this mobo.
Could it run with 4 x X1800XT without crossfire ? It's just for power supply testing purposes. Could I plug them to load the system and just use 1 monitor ? Would drivers let me use 4 monitors at same time (just 1 monitor by card, not usin dual DVI).
Many thanks.
i have ,so thats not it,maybe im not setting it up rightQuote:
Originally Posted by Dumo
It wasn't voltage something else :mad: :slapass:Quote:
Originally Posted by camouflage
now in stock for newegg...but...EWIZ is $50 cheaper with free ground shipping...pretty good deal.Quote:
Mine is in a fedex depot in NJ now... :) Im kinda bummed I won't get it til Monday most likely
I didn't know that there are 2 different version... =/
seems like p5w-dh is still the king see http://www.hardware.info/en-US/artic...S_Professional
SORRY!..i don't see it from that review which is really sub-par!Quote:
Originally Posted by Pjoeloe
Hi, I think Im doing something wrong, Ive tried this configuration, but I cant seem to get 4-4-4-12 timings on RAM, is it maybe that Im running 4x GB? (4x1gb G.Skill DDR2-800).Quote:
Also, I have gotten 72 ºC at 3500 Ghz maybe too high for 24/7 run, 50 ºC Iddle running 2 SP2004, what should be the highest temperature I should run my computer at 24/7?
Temperatures messured with Core Temp Beta 0.9.0.91
just bare in mind that one's settings on one puter will not necessarily work on another...to many variables...
loosen your memory timings and things will probably improve.
my view of temps:...if you do not game, don't sweat it..if you do game, just find what works best for your scenario.
:D You can buy mine when I own RD600............:lol:
