Hey Dangals...I don't want to question your modding knowledge as its probably far superior to mine but....are your tubes unclamped??? :O
Read the post above yours. ;) :up:
^^ ah missed that one ;) Yes Evil's clamps would look fantastic on that clean build. I assume going for the black color...or maybe some Chrome? :)
I love murderMod
So what's next for you? Htpc?
your photobucket bandwidth is exceeded :(
Thanks BA - here I am thinking I can have a few quiet months enjoying my current rig and now you have me contemplating another??? :rolleyes: Yeah I think a HTPC is going to be on the cards next but I am going to wait till I move so that way I can match it to the theatre room :up: Plus by then Charles should hopefully have something out that I can use ;)
Damn - I hate it when that happens....not much I can do at the moment but I will see if there is anything I can do about it.
amazing build dangals!
do you think that you could fit a quad radiator in there instead of the triple rad? im looking into the TJ07 for my watercooling build and just wanted to know if it would fit with a dual rad too
You can fit a quad radiator in :)
Thank you for the compliment :up:
yes you could definately fit a quad rad in - Charles did it here
When it comes time to do my next build I may consider using a quad rad and move my PA's into something else :shrug:
i guess i should have clarified but do you think that the quad rad and the dual rad would fit?? both together down there in the basement?? it looks a little cramped to me and i assume i would need to find a new place for the pumps right...
Yeah that makes sense thanks and any updates???
Nice job on the build! Could you fit a 140mm radiator in the bottom?
Congratulations on your build, I loved reading about it.
It's nice to see somone from OZ getting the recognition they deserve, well done.
I may in time pick you brain as to where you got all your hardware from, as I live in Perth and are just starting to look towards a water cooled PC.
This site "XS" has help immensely.
truly inspirational :up:
