very nice RootX, try Win2003 :). And.... is that 265 1:1 ? what timings?
Here I am again........ :D
Miss me???..... :D
No??? :(
OK.......
27sec for now...... :D
yes missed you :P omg thats nice Hipro what Windows are you using?
What are your GAT settings and what windows tweaks are you using?
Windows Server 2003...Quote:
ABIT IC7
Cas 2-5-2-2
Street Racer
Enhanced
4
Enable
Enable
That was ran with with the services working ...In registry only IRQ8Priority=1 and Disable Paging Executive=1
Paging file at D: and 768 - 768MB
wow, you must love your kingston bh6 pc2700 value ram.
Could you give me the week of these chips and the code on the sticker from kingston?
Very kind of you and excellent results!
Greece Powah :D
The sticker isn't up ther any more......chips are 4 of them 238D and the other 4 are 239D on both of my Ram modules......Quote:
Greece Powah :D
are chips on both sides of the module or just one side?
Single side......Quote:
the only valueram I have seen sofar here are dual side, damn seems I like I have to look harder :)
EDIT: what capictors did u use?
100uF / 16V ...Quote:
Are you crazy ultron? 1,9v on a prescott :eek: :D
Nice results Hipro, I love your Ram mods
Hi EmineM, :)Quote:
will give the 2003 server a go ;)
Mem is 2x512 pc3700EB, 1:1, 3-2-2-5@ 3.2V.
The AI7 i'm using is slower that the ic7 but i killed so many of them...
nice to see you again RootX :)
let hipro mod urs then maybe no kill :p I killed 2 or so but thats due to condensation. Seems like I need ai7 or ic7 because my asus p4c800 limits me to 250fsb alto my EE does way more :)
Hehe, not sure if hipro is gonna mod another ic7 for me, the last one I killed was his backup mobo http://www.thelab.gr/images/smilies/redface.gif
If you go for the AI7, prepare to work on the prommie's cpu kit a little, cause the socket is in 45 degrees angle and obstructs it.
Wow. Hipro, impressive as always... :thumbsup:
But could you show us the complete ram... I wonder what you did to the front side of the sticks ;)
There you go.......Simple things,not heavy duty stuff...... ;)Quote:
Trey are not like my older 512MB one......:D
Thanks. :)
Erm, but I also wondered what this solder joints on the upper edge of the stick are connected to... nearly looks like they are holding the heatplate ;)
Edit/
I already know the pic with the sinks/fans :D
Crazy... :lol:
......or like this 256MB Pelted one..... :D
The front side heatsink is the Thermaltake cooper one......I've soldered it with the ground of my Ram so as to be grounded for RF reasons......Quote:
Thanks. :)
Erm, but I also wondered what this solder joints on the upper edge of the stick are connected to... nearly looks like they hold the heatplate ;)
holy :banana: :banana: :banana: :banana:. Very nice Hipro, could I send you a pic of my KHX PC3200 BH5 and would you work out some mods for that?
btw RootX how did you mount the Mach II on the AI7 exactly.
Do you have a pic of your mod?
Sorry m8, no pic :(Quote:
What I did was to remove a bit(the curved one) from the socket handle and then trim the cpu kit in order not to be obstructed from the cpu socket...
Ain't that difficult, just make sure to insulate it properly with used seal string.
what a fuc*ing 3400+... under a mach 2... have to use my other 2 2 CG's .
but at least 33sek ;D
http://manner83.bei.t-online.de/bild...3-28-06-04.gif
Is that running EB? Very nice mem speed, try and up the core! :toast:Quote:
My 3400+ 64bit and ocz 3500eb on vnf3 250, does it in 39sec. Stock speeds, etc... Is that any good?
no thats 1x512MB OCZ PC4400 EL Gold Ldt!Quote:
Bad timings, huh? ;)Quote:
2,5-4-4-8 .... (SPD)Quote:
no thats the crappy 3400+ ....:mad:
my 3500+ s939 and my asus av8 deluxe arrived today, but it's too late to test, it's 11.22pm.
XP-M 2400+
NF7-S v2.0
http://www.hpautoelectrics.com/OverC...super%20pi.jpg
I got 35s on mine A64 @ 245 x 10 Mhz OCZ EB @ 3-3-2-8 1:1
better than nothing:
was hast du am epox gemacht um so einen hohen fsb zu bekommen?Quote:
ich hatte noch nie ein epox :D
my mobile run on a dfi lanparty nf2 ultra b. but i can't go higher with my watercooling
um bei englisch zu bleiben ;)
:lol:Quote:
LP B rulez :D
Seems that my tweaks gained something ;)
http://mbnet.fi/elixir/3.2E/SPI-1M-28.PNG
And thats R404 Mach2 cooled.
That looks good The Stilt :D
P.S. Any updates on the Datapage of the Super-Pi yet??.......The page seems to be missing or something....... :)
very nice stilt, what mobo?
IC7-Max3 @ IC7-G Downgrade, VTT, VDDR mods, IC7-G 24 bios.Quote:
did you just flash it to the abit ic7-g bios?
Why do that anyway?
Yep, hexedited IC7-G bios. It must be edited because it wont go in if it hasnt been edited. IC7-G bios is littlebit faster and, its more gentle when it comes to GAT settings ;)Quote:
Why do that anyway?
It's slower than 22 or 21 ones.........check it out over Pi-fast or whatever..... ;)Quote:
Whats the best IC7-G bios? The newest?
Shaved off another second with 5 more mhz on the fsb.
Thats on air with the top and rear fans in my PC-65 swapped out for 80mm tornados and a 92mm tornado on my SP-94. 1.85v set in bios.
As for me, it's the 21 and the 22 ones(the same)....Quote:
xp 2400-m @ 2591 mhz
superpi 41 sek.
12*216 with 512 b samsung pc 2700 and 512 mb corsair value
running 1:1
Nice... :toast:Quote:
Originally posted by KoGeR|Max
at last :D
Did you have to do the L12 mod to get that FSB?
And if you did, what was your highest FSB before the mod?
Thought I would submit this score with my P4.. Got to get the Dry Ice tube done :D
:D
http://www.silentworks.net/sekalaiset/1m_4100.jpg
Liquid cooling chilled to -10 celcius
Welcome to the sickness, Hilppa :D
me, 39 seks
sys @ sig
http://mitglied.lycos.de/sockeohyeah/nice.jpg
my old 1700 tbred-b
i used that exetime program, and i found that the time dropped by .10 to .15 for every 10mhz i added
btw this is with crappy air cooling, and a warm room, i cant wait for my chiller to be finished
P4 3.2E with stock cooler and voltage, anyone?
http://mbnet.fi/elixir/3.2E/SPI-1M-33.PNG
:D
Heres a slighly nicer version ... windows based this time :DQuote:
Originally posted by blinky
my old 1700 tbred-b
http://users.tpg.com.au/spark69/processtimer.jpg
Just hit the Refresh button when you want to calculate the super pi time.
still needs some work on resizing, but eh I am too lazy.
Download: ProcessTimer.exe
Enjoy.
I hope to get a 3.2E SL7KC (3.2GHz with only 1v) :D
Try this bios......You'll not notice any difference in Super-Pi but you'll notice some in other progs..... ;)Quote:
Downloaded from HERE.....
Thanks :)Quote:
Noticed that you changed: biosmessage, unhided Spread Spectrum and CPU setting selection, and if I´m not imaging, Sandra reports little better unbuffered ALU result ;)
Luckily I´ve got 10kg box of dry ice today :D
The Stilt ... how is 33sec in spi possible with 3800mhz and 237fsb ??
With tightest possible GAT settings, and specially tweaked OS (tweaks are worth of 12secs in 8M calculation) ;)Quote:
gigabyte k8nsnxp-939
2x 256 mushkin special @ 220 2-3-3-7 @ 2.7v
My SuperPI Time with 3200 + NewCastle
1M
http://www.forumdeluxx.de/gallery/da...SuperPI_1M.JPG
32M
http://www.forumdeluxx.de/gallery/da...uperPI_321.JPG
And with my first A64 ;) 3200+ ClawHammer with AirCooling
http://people.freenet.de/05121984/SuperPi342.JPG
http://www.myfavoritehacker.com/some...SuperPi-32.png
A64 3200+ NewCastle@1.95v
Corsair XMS 3500v1.1@3.3v
Epox 8KDAJ
Mach1 w/ R507
New CPU, new hights :D
Have look :thumbsup:
Wow, very nice. :toast:
:slobber: nice!
with a epox 8kda3j 32M finally at 2,5Ghz...
http://manner83.bei.t-online.de/bild...i_16_07_04.jpg
My new "lower frequency" 28sec........I did it once at 4408MHz and I'm trying to do it again......P4 3.4 EE :D
http://www.thelab.gr/images/Hipro5/P...417MHz_png.png
Nice Hipro5,
Thats fast for an EE:toast:
But you manage 4580 here:
[mbot] hipro5 - 27 - P4 3.4GHz EE @ 4580MHz 269.4MHz FSB 1:1 Cas 2-5-2-2 [/mbot]
http://www.thelab.gr/images/Hipro5/P..._27sec_png.png
Thanks my friend......I'll HAVE to find an EE with x18 multi though for higher frequncies +4700...... :D :toast:Quote:
Originally posted by Tom Holck
Nice Hipro5,
EDIT : Yes I know but I'm trying to get the 28 sec as low as I can...... :D
P4 3.0C (NW) @ 3.75GHz
RAM 5:4 (Infineon 6A @ 200MHz CL2-2-2-5)
Asus P4C800 Rev.2
http://mitglied.lycos.de/d3r8is/superpi.jpg
S.pi 1mb result of my team (Pisa-oc-Team ->Italy):
http://leghorn1.altervista.org/immagini/AMD/31_s.JPG
S.pi 32mb
http://leghorn1.altervista.org/immagini/AMD/32_m.JPG
SAE, can you tell me how you can banch at that frequency with a FSB so high?:eek: :toast: ... many compliments:)
Have you done a Sandra memory?:slobber:
Regards
Hmm. Good mem, enough stable voltages, good board, good cpu :DQuote:
Regards
Thx :)
I don't do Sandra usually, but the last one I did got me around 4.13k ALU/4k FLOAT...
I have been trying win2003 server, but it dosent seem to help.
Win2k sp2
2700Mhz (270*10 1:1 2.5-2-2-6-12-15) - 32sek
Win2003server
2760Mhz (276*10 1:1 2.5-2-2-6-12-15) - 32sek
2740Mhz (274*10 1:1 2.5-2-2-6-9-12) - 32sek
Im using the 2003 Server Standard. Its on the 3in1 2003 Server CD. Im I using the wrong version?
I want 31sek... grrrr
Is that a clawhammer? if so you might want to tweak it up a little.. (http://www.blackviper.com/WIN2K/servicecfg.htm) eventually try running without any drivers loaded.. oh and perhaps around 40mhz more :)
Yes, its a clawhammer.Quote:
The 2003server is a fresh install (20hours). Do i need to tweak the hell out of it to make it faster than than win2k?
I will try the tweaks, tho.
This sucks.. i allways seem to be missing that last bit of performance :mad:
I'm very impressive SAE, your system is very power; i know that you're writing with Intakeem, and that you're giving him advice to improve our result, and increase our FSB, so thanks!;)Quote:
Thx :)
(Can you send me, maybe in pvt or mail (mhrgala@tiscali.it), some link that it shows OCP mod?thx!:toast: )
Have a look here... :DQuote:
http://www.xtremesystems.org/forums/...646#post393646
http://www.truextreme.com/forums/showthread.php?t=31166
I dunno if the OCP mod is what you want though. :shrug:
I cannot explain what makes my fsb this high... ram is really good, maybe, and I do cool all important areas IMO. Play with your additional (alpha) timings. Try different voltages. Different ram slots, change the slots for each stick to test what the stick likes best... and so on.
Pulled 31s earlier today. :)
http://home.no.net/comerade/pc/superpi31s2xs.png
Edit: made 31s on 10MHz lower CPU-clock...
Edit2: made 31s on 25MHz lower CPU-clock using another OS...
Ahh.
My best result so far
The mem can't go higher with only 3.0v. I need an OCZ booster to give it more.
http://img48.exs.cx/img48/592/SuperPi12.jpg
Also finally cracked 31 secs :D
2.9ghz and 37s :(Quote:
Originally posted by thesaucier
Ahh.
http://membres.lycos.fr/boblemagnifi.../superpi37.png
welcome to xtremesystems bob :toast: :D :banana:
Thank :D while waiting for the dod to be really in the ixtremmmmmQuote:
http://forum.hardware.fr/images/perso/markdavis.gif
http://www.myfavoritehacker.com/some...uperPi-51s.png
51s doesn't seem too shabby for a 1.5GHz Dothan notebook. ;)
why is CPU Z reporting 600 mhz?
As soon as there is no load on the processor... it drops down to the 6x multiplier to save battery life.
my best time at 3803MHz in air with my 3.0E
http://membres.lycos.fr/cpulloverclock79/33.jpg
Id like to see how the 2ghz would doQuote:
hum... still optimising (damn vcore is unstable... set in bios 1,7v but under load it adds 0,1v and sometimes after switching on, only 1,6v)
http://manner83.bei.t-online.de/bild...i_28.07.04.gif
