Oh right :p:
But 42*C isnt too bad...I've seen people dual priming at over 50*C :confused:
Oh right :p:
yup, those guys may be firing their CPUs.:fact:Quote:
Originally Posted by K.I.T.T.
I always hear people saying that there is a 8-10C under-report of the actual temp. in DFI nf4 boards, dunno it is true or not.
Opty CCBWE 0551 VPMW
Note:
1.the same post as here:
http://www.xtremesystems.org/forums/...ad.php?t=88292
2.don't trust the temp!, thats is after stopping the dual prime, the real temp about 43-46 full load on both core
3. On stock cooling@5000 RPM
4. I live on tropical island so the damn temperature about 30-33C
5. Question:
is my max temperature just 49c?, thats what the Tcase said..
http://i19.photobucket.com/albums/b1...ic/2400mhz.jpg
Originally Posted by zentrad
no!
Originally Posted by kenofstephen
the dfi expert is under reporting temps...I have not seen this said about DFI Ultra/SLI-DR
KITT..your doing awesome
Originally Posted by nealh
the last central brain identifier tells you the offstet of each board!
Thanks for the comment :)Quote:
@ Sway : What do you mean by offset? As in how accurate the MB sensor is?
Yup i think thts what it means, oh and great clock, i see the WC has helped you up the mhz a bit. I would have to agree with you tht your temps seem a bit high, especially for WC, but without a proper calibrated diode near the CPU its hard to knowQuote:
exactly...Quote:
for mine it says: -7º wich means that to what the sensor on the board says I need to take out 7º...
for example in mine board (ultra-d) if it shows 24º (on the CPU temp) it is not accurate... the real temp its 17º!
Where abouts does it state the offset in CBId?
mobility->p-states and it is in the bottom... it says thermal offset! remember... last version only!
Ah...It says -5 in mine.
is my opty165 at default awesome too??:confused:
my thermal offset on my shuttle sn25p is 16C :s, I load at 39C @ 2.8g 1.36vcore, i cant see that being 55C load cause this little shuttle has an awsome cooler.
Mine :banana: :D :D
http://img351.imageshack.us/img351/8...rime6rm.th.jpg
That's cool!! So you're only 249C ;)
Do you keep a fire extinguisher next to that thing?Quote:
Originally Posted by ThorLite
Where are you guys getting this offset from?Quote:
Originally Posted by shuRe
LOL yes Prometeia Mach I power...... :DQuote:
I second this..and what does the offset mean..add or subtract ??
I think the thermal offset is the temperature you must ADD (not SUBTRACT) to the current cpu temp, in order to get a more accurate reading.
ok..but how do you find this value?Quote:
Originally Posted by Punkas
Also for all you guys using DFI Ultra D or SLI DR and DC opteron or X2...do you use orange or yellow slots?
and have you found any benefits over one vs another..I have always used my yellow slots
no... when you have to add it shows only the number ( for ex: 4) when you have to subtract it says -7!Quote:
to know the thermal offset download the last version of the central brain identifier!
I've been saying this about the thermal offset for a month.. and NO -7C doesn't mean subtract, it means add. The thermal offset is on the CPU, not the MOBO..
My 165 supposedly runs 22C idle on a big typhoon air cooler in 25C ambient. So am I really running 14C? :rolleyes: No I'm running 30C because the offset is -8C. My 148 with no offset ran 33C on the same setup BTW, so it's not the mobo.
Originally Posted by Repoman
so what means when there is no "-"?:nono:
