It is a scythe kama bay. I used it to mount the fan and radiator. You could mount a 3.5" disk behind it, but not with a fan and radiator.Quote:
Nephilim, that looks amazingly pimp! The bright pink is awsome! :P
Nephilim, that is just awesome. Phase, water, and system all in one (relatively) small box. Very impressive. :slobber:
Nephilim nice rig..
may i know what coolant u using? looking for something RED and UV reactive as well. keke
Very nice Nephilim!!
I like much the box.
Greetings.
Here is mine, that's a Vietnam Water Cooler, produced by Quang Huy Company, the only Water Cool company in my country :)
http://cssclanz.evonet.ro/DSC00061.JPG
http://cssclanz.evonet.ro/DSC00062.JPG
http://cssclanz.evonet.ro/DSC00063.JPG
http://cssclanz.evonet.ro/DSC00064.JPG
http://cssclanz.evonet.ro/DSC00065.JPG
http://cssclanz.evonet.ro/DSC00066.JPG
http://cssclanz.evonet.ro/DSC00070.JPG
http://cssclanz.evonet.ro/DSC00072.JPG
http://cssclanz.evonet.ro/DSC00075.JPG
http://cssclanz.evonet.ro/DSC00081.JPG
http://cssclanz.evonet.ro/11.jpg
Corner: hmm you need to bleed that somemore, lots of bubbles i see...
But the bubbles make it a little more interesting looking than solid water :p:Quote:
Originally Posted by septim
Actually how much performance is lost by having some small bubbles? Is it dangerous in any way?
Eh nevermind, that was when i first installed it, now the tank is filled with water and no bubbles :D
current, sry image captured with webcam
http://cssclanz.evonet.ro/tube.jpg
plenty dangerous, you never know when a certain ddc might get itself stuck upQuote:
Originally Posted by SparkyJJO
if too much air bubbles in a loop...
also with air bubbles passing thru a ddc makes it noisy...
but i guess it would really depend on what pump he's using...
OK. I know almost nothing about watercooling at this point, so please have patience with this n00b, I'll be asking questions every so often :)Quote:
Eventually when I have money and time I'll watercool, have a worklog with a case mod for it, everything :cool: I already have some parts picked out too :woot:
Threads like this one are inspiring....
Modding this stacker to fit a pa 120.3 in the bottom took me way longer than I thought it would. The stacker's designed to fit a 2x120mm rad in the bottom so some metalwork is required, but that's half the fun, right?
With thanks to Clokker for the inspiration.
EDIT: redid my loop thanks to SDkevin's rec.
http://img135.imageshack.us/img135/2682/dscn1280ip9.jpg
http://img135.imageshack.us/img135/8813/dscn1282pj6.jpg
New image shows reworked clamps, and filter - since I had to drain the loop to rework the clamps, I have to filter the water again.
http://img75.imageshack.us/img75/2255/dscn1307ac5.jpg
http://img135.imageshack.us/img135/9421/dscn1306il0.jpg
@vyper: re-clamp your T-Line, it is wrong! URGENT!
Edit: you shouldn't clamp at the tip of the barbs, I'm surprise that nothing is loose yet :) you should push the tube all the way in and clamp at the body of barbs not at very tip of the barbs
LOL! I just did the Same kind of mOdification to my Stacker, so it can fit a PA120.3 Used a Jig saw and soem other tools. It looks a lot more Home made than yours but it's clean and works perfectly ;) So many ways to Work on these Stackers! Ive seen so many Different watercooling set-up in that case that i had a lot of ideas on how to mount things when i build my first WC set-up in it (Of Course half were nto good lol). Now im at my second WC kit installed in it and i felt like it needed some Hard core Mod's to fit a Nice\Clean WC Set-up! Ill take some pics this morning!
Nice job! Vyper!
@Patriote: yeah, can't wait to see the pics. Like others have said, the Stacker's a forgiving case, it'll take a lot of punishment and still come out looking halfway ok. Meanwhile, I've got a lot of work ahead of me redoing my loop on account for my n00bness. :(
I feel left behind :( . Lol been planning on getting my first water cooling loop, but our friend Petra still hasn't managed to release his DDC top! Maybe I'll just bite the bullet and go with the Alphacool top but I haven't heard too many good things about PPCs lately. And damn Vyper the PA120.3 is huge. Dunno if I should install on the top of the case or the bottom... The top would look better because it would hide the rad and have a shmexy grill on the top but the bottom would allow for easier bleeding because res would be the highest point in the loop and also allow for easier wire management.... Aaaahhh.... Decisions decisions.. Advice?
Usama aka Ferrari Freak
I agonized for days and nights about whether to go top or bottom with the PA 120.3 - it's beast sized and the stacker won't take it without some modding. In the end, I went with bottom because:
1) there's so much space down there - at the top you have to worry about the psu and wires, the motherboard and peripherals, as well as the stock 80mm blowhole. Plus that plastic cap (for want of a better description) gets in the way of things.
2) I wanted push/pull with 6 yate loons and there just wouldn't be space at the top for that much radiator
3) Small temp difference between the top of the case and the bottom.
4) Slightly easier to bleed
Unless you plan on mounting it on the outside on top? But why, when the stacker is so roomy?
Creidiki put hit 120.3 in the front of his stacker. Also I hope you fixed the tubing problem and put them all the way onto the barbs.
I'll prolly put it bottom with 3 Yates because I need the front for other things.
I just bought an UV sensitive Coolant from Tt, any pics of my wc comming soon :)
thought I would be posting picks today but instead I had to dig out a bad motherboard for rma :banana: :banana: :banana: :banana:
(no leaks, It just decided to die when it was hardest to get at:mad: )
Here is a pic I took while I was checking for leaks (also before I made the rad mounts :P )
http://img227.imageshack.us/img227/7339/image274hw2.jpg
crappy cameraphone FTW lol
Finally finished my intel setup. :)
While testing of cooling -
http://213.202.211.105/gravedigga/pcbilder/umbau.jpg
Completed, and it works :D -
http://213.202.211.105/gravedigga/pcbilder/betrieb.jpg
here's mine. i had to make a plate to mount my s939 block to my sAM2 system....
http://img180.imageshack.us/img180/1075/cpuva3.jpg
http://img156.imageshack.us/img156/5900/cpuleftlq0.jpg
http://img156.imageshack.us/img156/8434/psubp3.jpg
http://img151.imageshack.us/img151/2...lethingkr5.jpg
http://img151.imageshack.us/img151/7941/pumpow2.jpg
Nice!Quote:
Originally Posted by flclisgreat
thanks^
b4 anybody says anything, its a b!tch to do wire manedgement with 2 psu's(and yes the second psu is dusty, i know, you don't have to say it)
oh and this is my first WC setup, i need to take out a little hose to
