guys will ask again
what version of AI SUITE II are u using or where's the latest to download (i remember the one on ASUS its like old and new was posted here like 1.04 wich im using but has no digi/vrm on it)
thanks
Sergio
guys will ask again
thanks
Sergio
everthingīs ok buddy, just a little stressed :D
recignized that 1.04 got no digi/vrm, thatīs why i am still @1.02.
will look @ you @msn soon ;)
cheeeers mate
I used the bios flash back, now Im back on 2105. After trying the flaky bios posted on the lsat page, I have been unable to change the CPU multiplier on any bios. Any suggestions on what is causing this?
Got a link?
geeks has it for $159.99 refurbished as well, so plenty of choices radaja.
http://www.geeks.com/details.asp?inv...X-PB-R&cat=MBB
it just went out of stock:(
still mwave for $20 more is still a great deal.
I tried to flash to this bios a few days ago, something went wrong. I got 00 post code and board wouldnt boot. So I switched bios chips and tried flashing the other bios, the flash took, but I was unable to change the CPU multi. I used the rog connect and flash back to 2105 bios on one chip, the 140x (cant remember) on the other bios chip. I have been unable to change the CPU multiplier even after flashing back to older bios that had been working fine. Spent several hours trying but with no luck. Any suggestions on what the problem may be?
no ? whit new bios I can use all x56 an blck is 53x103.9 max on watercooling
bios 2105 max blck 102
Anressergio and I have been messing with this trying to get somethingto work, but so far nothing is helping.
I lost some settings, even after reflashing several times. Either something simple I am missing, or the bad flash from a few days ago totally fooked the board :shrug:.
http://img268.imageshack.us/img268/9...0305130342.png
Uploaded with ImageShack.us
