Very clean nice job. So um what are the tubes going to in your bay area, is there another pump in there?
Chad
Hey Ogge, where is the outlet tube on your reservoir going?
Looks like to the pump inlet.
If u move Micro Res on the upper compartment of the case u'll have a way easier to fill/bleed loop, plus a cleaner route...
Well, bought a Powercolor 5870 with EK FC block and installed it yesterday, case is also pretty new, bought it last month. My old CM Stacker served me well but I felt it was time for a change after 5 years.
http://i3.photobucket.com/albums/y55...2032010383.jpg
Zip-tie madness
http://i3.photobucket.com/albums/y55...3032010389.jpg
If you're wondering why I don't have my reservoir + pump in the space below its because the Laing D5/Swiftech MCP655 won't fit. Dumb as I am I didn't check that before purchase. Oh well, I'm very pleased with it overall.
Here is my watercooling. and yes, that is a 360 in the front :)
http://i42.tinypic.com/30shibp.jpg
http://i41.tinypic.com/2vs17nk.jpg
http://i39.tinypic.com/2ch9ks9.jpg
http://upload.centerzone.it/images/3...6515_thumb.jpg
http://upload.centerzone.it/images/0...9912_thumb.jpg
http://upload.centerzone.it/images/2...0188_thumb.jpg
updated with nanoxia nanoflex white tubing :D
sure, here you go
part 1 http://www.flickr.com/photos/studiov...42536199/show/
part 2 http://www.flickr.com/photos/studiov...14269586/show/
could it be that one: click ??
More Pics Link :
http://www.parkoz.com/zboard/view.ph...c=asc&no=37292
Talk about a headache!
WAIT A MINUTE. I had to take a double take at the first photo. Does that have two mobos installed?
@wrcceo ... is that case custom made, or is it some sort of server case you modded? I've never seen anything like it, and it's incredible. Nice job regardless.
http://img24.imageshack.us/img24/9085/comp21.jpg
http://img251.imageshack.us/img251/5677/comp17.jpg
http://img299.imageshack.us/img299/3604/comp16.jpg
http://img42.imageshack.us/img42/4439/comp11.jpg
http://img408.imageshack.us/img408/1976/comp10.jpg
SPEC:
evga classifieds 3 sli
corei7 920 @ 4450
memory Gskill trident 6 GB
vga:Ati 5870
case:obsidian 800d
watercooling :
radiator : feser monsta
pump : 2 mcp355
tubing : tygon
resevoir : bay xspc
Ogge_swe What do you have CPU and GPU temperature in idlu and loadu and how you wound cpu?
Nice build wrcceo... Did you purchase that case in korea?
I i7 processor and video card, gtx 295, what do you have temp in idlu and loadu?
