@ Everybody
Does anybody know where I can get [[ TEAM Xtreem with D9 ]] to germany ? :shrug:
@ Everybody
thanks alot,
think will get one :)
Before buying contact them asking is description correct.
Not much to worry about buying from MemoryC, especially Team Xtreem.
Having a bit of fun with my CellShock CS2221650 "Red Devil" kit and my Maximus Formula, I managed single SuperPi 32M stability@DDR2-1200 4-4-4-4 with 2.50v BIOS set (=2.56v DMM). Ignore the PC Probe II reading, it's a bit high.
http://img27.imageshack.us/img27/944...4pl532mcs2.jpg
{[ Before buying contact them asking is description correct. ]]
@ Kuebk:
too late, I already bought a kit, i hope i can reach something about 1400+:down:
My 1300C6 I got from them.:up:
PC2-9600-now cheaper 20 Euro
PC2-10400-now higher 7 Euro
PC2-10400,VDimm 2.38
http://www.yourpicbox.com/images/oEBIeDSoO9030.png
http://valid.canardpc.com/show_oc.php?id=659865
Afair new Goodrams Pro 2x1 can reach 700mhz easily, they are made of d9hcd.
Gigabyte GA-EP45-UD3P (Rev. 1.0) - F10e
MB Intelligent Tweaker(M.I.T.)
Robust Graphics Booster ..............: [Fast]
CPU Clock Ratio ......................: [10X]
x Fine CPU Clock Ratio................: +0.0
CPU Frequency ........................: 4.3GHz( 430x10)
********** Clock Chip Control ********
>>>>> Standard Clock Control
CPU Host Clock Control................: [Enabled]
x CPU Host Frequency(Mhz).............: [430]
PCI Express Frequency(Mhz)............: [101]
C.I.A.2...............................: [Disabled]
>>>>> Advanced Clock Control..........: [Press Enter]
CPU Clock Drive.......................: [800mV]
PCI Express Clock Drive...............: [900mV]
CPU Clock Skew........................: [ 0ps]
MCH Clock Skew........................: [ 0ps]
******** DRAM Performance Control ********
Performance Enhance...................: [Standard]
Extreme Memory Profile(X.M.P.)........: [Disabled]
(G)MCH Frequency Latch................: [Auto]
System Memory Multiplier (SPD)........: [3.00A]
Memory Frequency(Mhz).....800.........: 1290
DRAM Timing Selectable (SPD)..........: [Manual]
>>>>> Standard Timing Control
x CAS Latency Time................5...: [ 5]
x tRCD ...........................5...: [ 5]
x tRP.............................5...: [ 5]
x tRAS...........................18...: [15]
>>>>> Advanced Timing Control.........: [Press Enter]
x tRRD............................3...: [ Auto]
x tWTR............................3...: [ Auto]
x tWR.............................6...: [ Auto]
x tRFC...........................42...: [Auto]
x tRTP............................3...: [ Auto]
x Command Rate (CMD) .............0...: [ Auto]
>>>>> Channel A Timing Settings.......: [Press Enter]
x Static tRead Value.............7...: [ 7]
x tRD Phase0 Adjustment...........0...: Auto
x tRD Phase1 Adjustment...........0...: Auto
x tRD Phase2 Adjustment ..........0...: Auto
x tRD Phase3 Adjustment...........0...: Auto
x Trd2rd(Different Rank)..........6...: Auto
x Twr2wr(Different Rank)..........6...: Auto
x Twr2rd(Different Rank)..........5...: Auto
x Trd2wr(Same/Diff Rank)..........8...: Auto
x DIMM1 Clock Skew Control (ps).......: Auto
x DIMM2 Clock Skew Control (ps).......: Auto
x DDR Write Training..................: Auto
>>>>> Channel A Driving Settings......: [Press Enter]
x Driving Strength Profile............: [1300MHz]
x Data Driving Pull-Up Level..........: Auto
x Cmd Driving Pull-Up level...........: Auto
x Ctrl Driving Pull-Up Level..........: Auto
x Clk Driving Pull-Up Level...........: Auto
x Data Driving Pull-Down Level........: Auto
x Cmd Driving Pull-Down level.........: Auto
x Ctrl Driving Pull-Down Level........: Auto
x Clk Driving Pull-Down Level.........: Auto
>>>>> Channel B Timing Settings.......: [Press Enter]
>>>>> Channel B Driving Settings......: [Press Enter]
****** Motherboard Voltage Control ******
Voltage Types..........Normal...........Current
>>> CPU
Load-Line Calibration.................: [Enabled]
CPU Vcore..............1.17500V.......: [1.2500V]
CPU Termination........1.200V.........: [1.220V]
CPU PLL................1.500V.........: [1.570V]
CPU Reference..........0.760V.........: [Auto]
>>> MCH/ICH
MCH Core...............1.100V.........: [1.240V]
MCH Reference..........0.760V.........: [Auto]
MCH/DRAM Reference.....0.900V.........: [Auto]
ICH I/O................1.500V.........: [Auto]
ICH Core...............1.100V.........: [Auto]
>>> DRAM
DRAM Voltage...........1.800V.........: [2.420V]
DRAM Termination.......0.900V.........: [Auto]
Channel A Reference....0.900V.........: [Auto]
Channel B Reference....0.900V.........: [Auto]
http://img139.imageshack.us/img139/9...0818044605.png
How about Crucial Lanfest D9GMH ? Is it worth buying?
Imo it's better to buy 1066 kits from crucial than 800.
Well, if you can get them for cheap, why not! Even Crucial's 5300s were good memory! :up:
I can get them for about 25 euros, i need 1250mhz so i think these mems fit there :)
That price is okay in my opinion, go for it and post some results!
I would even say that some of them were better than 6400 kits.
Doesn't sound bad, I paid for mine 20usd. For such speed you will probably need around 2.4v [this is what my lanfest's wants to] to work at ~600mhz. And that's what I'm consider as pretty high voltage for 24/7 use.
Firstly im not going to use this mem 24/7. We need it to get over 600fsb because atm kingston memory blocks us. it does only 1150MHz on 2.35v (real 2.37v).
Sorry for spamming this thread, but I'm searching a RamPot for Overclocking the Ram with Dice or go LN2 and
how can I store in Dice ?
Need I an ICEBOX to store it ?
It should be available to germany and the price should be a bit ......:down:
:( school is going on again on Monday :(:(:(:(:shakes::shrug::down:
I've no idea where you can purchase a proper ram pot.
I store my dry ice in a thick walled polystyrene box, with a thick base and a thick lid. This is also placed in another polystyrene or cardboard box. I place broken panels of polystyrene on top of the dry ice in the box also to aid insulation.
aslanwas, PM Nanok for his RAMpot, he can build one for you.
