It should be different, 891028 bytes to be exact. It's just the BIOS code without the installer junk. If you burn the ISO, the .bio file on the cd is exactly the same size.Quote:
Originally Posted by shimmishim
It would be really awesome If they would support SLI too but doubt I'll see it during my lifetime...
But they are unlocked up for extreme edition chips (X6800 and QX6700) I thought, just downward unlocking isn't available for any chips. Is this correct?Quote:
Is ANYONE running 4 sticks of RAM (1gb each for a total of 4gb) on this board without any issues? I have four sticks of Corsair XMS2 DDR800 and it's only stable with 2 sticks. When I run four, I can't run memtest86+ without it either freezing or erroring at stock timings and stock volts (even tried up to 2.2v and still having issues).
Originally Posted by Eluzion
Yup. I'm using 4 sticks. I had to up my mem voltage to 2.28v (from 2.20) and all good now. :toast:
How does overclocking the memory work exactly? Kinda new to the whole "frequency/divider" thing.
My Corsairs are DDR2-800 @ 1.9v...but should I leave them as such in the BIOS? Or Drop to 667? Does it depend what my FSB is set at?
Tried some oc attempts.
9x300 for 2700mhz. Raised cpu voltage to 1.3625. This is game stable so far. Gonna do a full Orthos for at least a few hours.
9x334 for 3006mhz. Errored in Orthos after 22secs at stock voltage. Raised a bit. Then Errored after 3:45.
Northbridge heatsink feeling a little hot. So I think I won't bother with that anymore till I get a fan for it. Anyone got any recommendations on that?
Thanks.
What kind of RAM are you running? Not familiar with Team Xtreem, hehe. Also, what vmch are you running?Quote:
Originally Posted by theonlybabyface
I wish someone would have answered that question for me earlier.Quote:
Originally Posted by gtj
But that said, VT tech may not be used by Windows specifically but if you're using VMWare or Parallels, it seriously accelerates their hypervisors and makes the virtualization speed close to native.
I use VMWare constantly so I was a bit pissed about having to disable one of the technologies that was a serious driving force behind me switching to Intel from AMD.
Nice to know I can turn it back on now lol.
Update on my overclocking situation: I got a crappy E6300. This thing will not POST at 3GHz whether in my machine or my friend's DS3 (and he's got a lot more Intel experience than I do). Figures out of all the possibilities, I'd get a weak overclocker.
Doesn't really matter though. This board is a lot more stable than the DQ6 was, it has compatibility, and honestly I really don't *NEED* more than the 2.8GHz I'm running it on 24/7, I just *WANT* it.
Its still kind of a bummer in a way because I'm running like 1.275 volts to the processor and its totally stable. It sucks to be teased into thinking it could go higher.
See the calculator in my sig.Quote:
Originally Posted by SteveLord
If you left the memory settings at default/800 and you set the fsb to 334 then you're running the corsairs at ddr2-1004. :)
Team Xtreem is excellent memory and I've had them all pretty much. OCZ, Mushkin, Corsair etc and this stuff is consistently the best. Vmch is at the default. In fact all of my voltages are at default except for the memory. Here are my specs for an everyday quiet and fast machine:Quote:
Xeon 3060 @ 3.2 Ghz default voltage (Tuniq Tower)
4 GB's Team Xtreem 3-3-3-8 1:1 2.28v
Everything else @ default (vmch and vfsb)
Hm, what's default vmch again? I forgot, lol.
My memory errors in memtest86+ if I run anything less than 1.65 vmch. Can't get four sticks to run stable for the life of me...
1.525Quote:
Timings?Quote:
Does anyone know if the onboard marvell controller has a vista driver? I seem to recall a link some time back to the driver but can't find it now. I would like to get this thing working in vista if possible. Thanks.
Not built in to vista but the package on Intel's site works fine for 32-bit vista.Quote:
Originally Posted by astrodave
I tried at the default 5-5-5-12. This RAM is suppose to run at 1.9v but I had it up to 2.2v with 1.65vmch.Quote:
With 2 sticks, runs perfectly stable at 4-4-4-12 at 1.9v with 1.65vmch.
Test the new sticks individually and see which one is no good....
I still havent been able to isolate the cause of my keyboard (G15) disconnecting and powering off for a short time, then starting back up and I get the reinstall beeps from windows as its being redetected? Might it be a keyboard error or something with the board I havent quite figured out. PCIE Freq has nothing to do with it, and ive reinstalled drivers and such. Its been happening for about a month, although it could be the keyboard, and I have also switched around the port it was plugged into.
Asking again because I may buy this board tonight and I want to be sure...
Honestly, I have keyboard and mouse problems myself. Figured I was the only one so I wasn't going to worry about it.Quote:
Originally Posted by ChaosMinionX
If I have them plugged into the PS/2 port, sometimes Windows won't detect one or the other.
If I have them in USB, its no problem, but then when I enter BIOS, it freezes after a few seconds so I have to switch back to PS/2. >_<
Correct.Quote:
Originally Posted by Speederlander
what a strange problem! i've had this board for a few weeks now and have yet to have a freeze or lock up with my usb keyboard in the bios....Quote:
Originally Posted by EtherealRemnant
I'll be going through menus and everything is going great and then suddenly, it locks up. But it doesn't completely freeze because whenever I push a button, the lower right part of the screen flashes slightly.Quote:
Its the weirdest thing I've ever seen before in my life. Only happens when I use the restore jumper too.
I'm for one.Quote:
2x Crucial Ballistix Tracer + 2x Crucial Ballistix
400MHz 3-3-3-8 2.32V
vMCH = default
http://www.xtremesystems.org/forums/...postcount=1713
i can't seem to get crystalcpuid to work properly. i did everything step by step but the mult still stays at 10x...
kinda sucks when you're trying to push mem to the edge with a 10x mult :)
anyone else have directions or tips to get it to work properly?
