IHS: To Remove, or Not To Remove
been thinking about removing the ihs on my 4400, what are the pro's and cons
(i know removing takes out the barrier between your cooling solution and the heat source, but what sort of temp gains can i expect?)
also, i have read (in this thread i believe) that removing makes them a little fragile... i dont lan, but my g/f has no concept of Delicate Hardware whatsoever...
would a lighter (but less effective) cooling solution like the sl-120 (may have gotten code a little wrong... the 120mm TR cooler that fits all motherboards??) suffice for this? (light enough not to cause any problems if the case was bumped)
anyone have any High Quality Hearsay about ihs+air cooling solutions? :P tossing up between:
-ttBT with ac12(silence will be a consideration on one pc im afraid :( ) (possibly side panel intake duct) heavy?
-xp-90c with 90-120mm fan adapter with ac12 (artic cooling "cage"-look 12cm fan.. 74cfm, seems ok?) its heavy though
-sl-120, ac12+ side panel intake duct
anyone had any experience with the asetek vapo micro's? online reviews about it are not great...
ok.. /OT... soz for the question bombardment :P recommend better place to ask these questions at will :P
