no GPU cooling ???
still looks fab.
no GPU cooling ???
still looks fab.
http://i9.photobucket.com/albums/a96...6/bigrig01.jpg
http://i9.photobucket.com/albums/a96.../bigrig002.jpg
Only *just* finished the system around 30 mins ago and it's running nicely, need to do a big tidy up and hide some sins :p
Can't really compete with a lot of cases here in aesthetics at the moment, hopefully will look much better when it's finished.
ok :toast:Quote:
Originally Posted by Spam
With this card? no.. lol :stick:Quote:
no GPU cooling ???
http://img367.imageshack.us/img367/5...5mediumxh0.jpg
http://img131.imageshack.us/img131/4...4mediummk5.jpg
Respect :banana:
@ cl4w. Nice work! :up:
What 120mm fans are u using?
Those look like aerocool silver lightning fans.Quote:
Originally Posted by JoeBar
Very nice work! Why aren't you cooling the GPU though? Or are you waiting on that until you get a more powerful card?
right :)Quote:
Originally Posted by SparkyJJO
thx.Quote:
I'll wait for a more powerful card, but noch this month, i spend to much for this computer... :nono:
that's a very nice setup, good work! :DQuote:
Originally Posted by Omarko
http://www.nickfire.com/photo/wcforums/wc%20011.jpg
http://www.nickfire.com/photo/wcforums/wc%20016.jpg
http://www.nickfire.com/photo/wcforums/wc%20028.jpg
http://www.nickfire.com/photo/wcforu...lbip%20002.jpg
http://www.nickfire.com/photo/wcforu...lbip%20004.jpg
http://www.nickfire.com/photo/wcforu...lbip%20006.jpg
http://www.nickfire.com/photo/wcforu...lbip%20008.jpg
http://www.nickfire.com/photo/wcforu...lbip%20009.jpg
Specs:
Naked 3000+ Venice @ 2.5GHz, Stock Voltage
2x1GB PDP Patriot PC3200LLK @ 228MHz 2.5-3-3-7, 2.75v
MSI K8N Neo4 Platinum
MSI 7900GS @ 600/1725 (Stock 450/1333)
SB Live! 24-Bit
160GB Seagate Barracuda 7200.9
2x NEC Burners
Card Reader
Tagan 2Force 480w Custom Sleeved by FrozenCPU
Lian Li PC-7B Plus II, w/Window, Modded
Water Specs:
2x Black Ice Pro Radiators
--Front, 2x Lian Li (~55CFM) Push-Pull --Rear, 2x Yate Loon (~48CFM) Push-Pull
AquaXtreme MP-05 Pro w/Acrylic X-Nozzle Mid-Plate
AquaXtreme 50z DC Pump
DangerDen Maze4 Acetal
1/2" ID, 13/16" OD Masterkleer Tubing
Pentosin G11 Blue Additive
Petras Delrin Fillport
My god that tubing is thick. How did you make that hole for the t-line cap?
I know, it rocks :D. I used a 1" holesaw with a bit in the middle for the tline cap. I didn't measure, nor did I tape anything. I just kind of made sure nothing was near it, made sure it was fairly center and drilled away. Came out awesome, too. Not one bit of silver aluminum is showing around the cap. :D
how are your temps, NickS? curious since you have 2 120 rads in there.
NickS, Ilike that colour scheme. I like it so much it is what I am in the process of building with my black v1000 :)
And if you don't mind me asking, what is the water additive you are using?
@ Aiya, they're great. :) Anywhere from 34-38*C load for CPU (depending on room temp) and 30-40*C idle-load for GPU depending on room temp. :)
@ Munnsyr, thnx man :) I'm using Pentosin G11 blue. You can find it cheap @ PetrasTechShop.com :D
My First wc rig.
Thermochill PA120.1
Alphacool DDC pro
Aquaxtreme MP-05 LE
http://www.xtremesystems.org/forums/...1&d=1158602231
http://www.xtremesystems.org/forums/...1&d=1158602922
http://www.xtremesystems.org/forums/...1&d=1158604278
Nice job Adaman! But is it just me of the tube going out of your t-line to your pump is kinda bending a bit too much?
It is a pretty tight bend. I'm considering putting some cool sleeves on it.Quote:
Originally Posted by Patriote
Would be a great idea ;)
First time WC'ing!
http://img133.imageshack.us/img133/1...ull1362ls5.jpg
http://img133.imageshack.us/img133/8...ull1364uc9.jpg
http://img133.imageshack.us/img133/5...ull1370ku6.jpg
http://img133.imageshack.us/img133/9...ull1366uo1.jpg
http://img133.imageshack.us/img133/3...ull1368ei3.jpg
More here..
http://www.techenclave.com/forums/ri...allery-52.html
PatrickClouds, that is just beautiful. Respect :toast: .
Usama aka Ferrari Freak
heres my first ever Watercooling setup.
http://img105.imageshack.us/img105/1...adytogoqv5.jpg
That's very nice. Good WM... maybe you'll try to use a normal & folded IDE cable. ;)
:toast:
@ adamant415
in the front on your lian li it seems as though you have a dual/triple bay cooler...??
is that a lian li hard drive cage, or is it like a scythe "kama bay", if so where did you get either from (and could you mount a 3.5" disk behind the kama bay if it is indeed that???)..
cheers,
houlty
I FINALLY have my build set up for good!!!
Dont laugh at my use of tape, or foam for the HD cage.
I used a bit too much tubing in a few places but it is fine until I rebuild in 2008.
I'll either extend the pump out or turn the case to make the t-line vertical to bleed... Probably do that for a week and then she is going to be closed and locked and the key is going to be thrown away... I have been slowly working my way to this machine since about April and she is finally done. (Well, gonna add another exhaust fan but that is nothin')
My specs are:
Naked Opty 165 CCBBE 0610 3.0ghz at 1.475
DFI Lanparty Ultra-D
MSI x1900xtx
2x74gb Raptor 0FCL0 in RAID 0
160gb Seagate Storage
Ultra X-finity 500w PSU
Swiftech Storm CPU Block
Maze 4 GPU Block
Modded MCP350
BIP II w/ two Yate Loons in Pull
7/16" Masterkleer
http://i35.photobucket.com/albums/d1...h_100_0409.jpg
http://i35.photobucket.com/albums/d1...h_100_0408.jpg
http://i35.photobucket.com/albums/d1...h_100_0407.jpg
http://i35.photobucket.com/albums/d1...h_100_0406.jpg
http://i35.photobucket.com/albums/d1...h_100_0405.jpg
http://i35.photobucket.com/albums/d1...h_100_0403.jpg
http://i35.photobucket.com/albums/d1...h_100_0402.jpg
