one of the chips i bought from egg is very similar batch..
did you say you tried 56x? ss is showing 53 multi?:confused:
YES sorry
fast test on water x56 ;) next test whit SS an 3Dmark
Attachment 121279
Here is my old and dusty L040B208 2600K still kicking. A quick run of 3DM11 at 5300mhz and a run of Cinebench R11.5 at 5400mhz I did this morning.:D
after testing a few cpu, I find that on air/water and sub zero is different. I almost sold my 5.3ghz on air but unexpectedly the cpu did 5.78ghz on ln2
2500K Batch L132B475
further results follow :cool:
http://www.abload.de/thumb/4ghzvcore1.058aces71n.jpg http://www.abload.de/thumb/45ghzvcore1.164acey7l9.jpg http://www.abload.de/thumb/5ghzvcore1.305acek7ex.jpg http://www.abload.de/thumb/5.2ghzvcore1.399aceq7fx.jpg
Impressive !
5455 is max. boot :(
5.4Ghz boot with 1.45 Vcore
batch: 3134B173
max multi: 53
max mhz.. seemed like 5300
http://img219.imageshack.us/img219/6...ncytesting.gif
cooling was under SS -47 to -44 on evap
Very nice daily chip Ace!
I just bought a 3113Bxx 2500K that so far is running LinX AVX at 4.6Ghz with 1.24V under load. Once I find the max, Ill post all the details. Seems like a great low volt clocking chip so far.
3113B776 2500K
Gig Z68X-UD3H-B3 1.3
H60
2x2Gb Gskill RipjawsX 1600 7-8-7-20 1.5V
1.36V in BIOS with Lvl5 LLC, 1.404V idle, 1.332V load.
Auto for rest of voltage accept PLL undervolt to 1.6, and Vdimm at 1.515V.
http://i56.tinypic.com/2yzmwhx.jpg
hi cecil.. that is not your max multi is it? :p:
nice clock :)
I just bought my first 2500K to try and its a lemon ..... it needs 1.55v to boot at 5ghz and its not even stable .....
2700Ks coming up:)
Will they be binned 2600K?
I will find out soon:) Imo, it will be a little higher average max multi than 2600K...probly average 54X/55X?
I have to admit though that BD FX chip is more fun to oc:) It took me longer to find its sweet spot with non LN2 cooling (and its still scaling up with more cold) whereas SB only took 15 minutes to find its max Mhz. Lol
batch 3115B564
max multi 52
max clock 5252mhz
man.. 4 31XXXB and all aren't that good... 52, 52,52,53 :(
martin you got lucky man.. with that 56x
It is certainly not like the early days of Sandy.
I havent had cooling to test a max multi, but Im on my 4th 2500K, and this one is best for clock/voltage scaling. The first one did 5 stable but needed a ton of volts and was best ran at 4.5 1.35v. The second really only could do 4.4 with 1.35. The new C batch I got did 4.6 with 1.35. My 3113B can do 4.8 with 1.33V. So Id say the newer ones are doing better daily, but not as well for benching.
I have gotten two x55 and a x57 from Costa Rica, and only one x55 from Malaysia, and I would agree with the newer chips being better than the old ones.
Can any of you guys bench 56x on water? I have a cpu that does 56x with wall at 5650 but I cant get it 3D stable at anthing over 5250-5300, it requires alot of juice to do that too - 1.65-1.7v - do you think cold will help? Is the chip stuffed? It was as well have a wall at 5300 since I cant use the 56x anyway (except for SuperPi)...
Based on my personal binning experience, 30+ pcs. 2600Ks yielded (1) 58X when stick with good known batch/es (luck factor excluded)...Hopefully it will take less with 2700K
If its wall @ 5650 Mhz then definitely you can bench (with cold) @ 5630ish at least with 4C/4T
5650 was with 4c/8t too, I tried disabling and didnt get any more out of it.
What rams are you guys using for C7 at high clocks?
