Post your settings using the bios template at the beginning of the thread. It will be easier for folks to help you. 12Gb should run on it, try using the SPD setting for your memory.Quote:
Greatings to everyone,
I'm a proud howner of a Rampage II Extreme as almost all of you guys here in this thread are :up: ...but i have 2 problems... :(
First problem: I don't know the "art of overclocking" as almost all you guys do... in other words i'm practically a noob... so please be gentle at me :p:
Second problem: I'm going out of my mind trying to get my ram working at their default speed... :confused:
So i have the following hardware:
Rampage II Extreme (1306 bios)
i7 965 EE
12GB OCZ DDR3 PC3-15000 CL9 Edition Reaper Low-Voltage Triple Channel (1866MHz, CL 9-9-9-28)
...and i have not been able so far to have all the 12GB running at 1866MHz (9-9-9-28)... it never entered windows (Vista ultimate 64) it doesnt even post :(
I'm not overclocking the cpu, it's runing at the default 3.2GHz, i'm using 1,65V DRAM voltage and i'm setting the ram timings manualy (9-9-9-28) and of course i set DRAM frequency to DDR3-1866MHz... i have tried lots of values for QPI/DRAM, so i'm not sure anymore, but i think the max i went was 1,4V...
I tried the same settings with just one stick (2GB) and it works... tried with 2 sticks (4GB) and it works... with 3 sticks (6GB) it works but it shows errors in prime95... :(
So i need help from you guys...
The big question is:
Is it possible AT ALL to have 12GB of DDR3 running at 1866MHz 9-9-9-28 on this mainboard ???? :shrug:
The other questions are:
If it is possible... are these OCZ sticks up to the task? :confused:
Also, if it is possible... what settings do i need to mess with?... for instance, how far should/can i take the QPI/DRAM ?
Like i said in the begining, i'm new at this bios tweaking... so i apologise for my basic/noob questions :D
I have read all this thread from page 1 and i have seen lots of you guys running 12/6GB of 2000/1866MHz sticks at lower speeds (1600MHz, for instance) that's why my big question is: Is it possible at all to run 12GB at 1866MHz ?
Later on i plan to overclock the 965EE on water cooling... but right now i just wanted to use my ram at it's max speed... but of course i don't want to fry the 900€ i7 :shakes:
Thanx alot for your time... and keep pushing those RiiE :clap:
