Yes set it to 100ºC, your temps will show 5ºC higher but are still very good.
you are right in my screen shoot above Everest temps about 5c higher .
Np thanks Quattro. And good job on your o/c so far. Also you have one of the better Q9650s i see ;)
believe me mine is an average batch iv seen much much better ones here at XS .
FYI for anyone that's going to try, the Thermalright HR-05 SLI/IFX when used on the SB (Southbridge) on this board will not allow you to install a double wide graphics card. I installed the HR-05 SLI/IFX and realized the screw that goes through from the bottom of the board sticks up tall enough to hit the underside of a graphics card, such as a GTX 280/4870 X2.
http://i442.photobucket.com/albums/q...s/IMG_1509.jpg
...and...
http://i442.photobucket.com/albums/q...s/IMG_1513.jpg
Any suggestions for a SB heatsink? I'm looking at the Enzotech CNB-S1L (fanless), but the spacings on the push-pins don't go straight into the board. What I'm thinking of doing is filing off the "arms" on the CNB-S1L and using 3M 8815 thermal tape to secure the copper heatsink to the SB chip.
http://www.performance-pcs.com/catal...ducts_id=22980
This tape is the same thermal tape used on Enzotech's BMR-C1 copper MOSFET heatsinks. Performance PC's sells a 2"x2" square of this tape for $2.95. Anyone think this will work, or have any alternative ideas?
Thanks.
enzotech low profile
Drill a hole and use isolation tape :banana:
Just kidding, any low profil cu heatsink will do the trick.
Do you think the 3M 8815 thermal tape will be sufficient to hold the Enzotech CNB-S1L heatsink on the Southbridge chip? I have to say this tape seems very "grippy" with the BMR-C1s I've got. I don't have much confidence in the push-pins, especially when they have to sit at an angle going into the board.
Why dont you just cut the screws shorter on the top, and use nuts instead of those tall ones that came with the heatsink, come on its a easy fix.
Here's what I did with the other mounting nuts -
RE cooling replace
It's kinda hard to see but I used the J hooks.
Sounds like the CNB-S1L is the answer then. How do you attach the CNB-S1L to your Southbridge? Do you use the push-pins or are you using some other method? My options are thermal tape, push-pins and Artic epoxy.
For the Northbridge (NB), I'm going to use a Noctua NH-U6 fanless. I'll have a medium-speed Panaflo blowing a lot of air into the case sitting at the front of the case. I'll have the same type of fan at the rear withdrawing air out.
It's odd as your board looks very similar to my own, referring to the copper heatsinks at the NB area, the Enzotech MST-81's and NB heatsink. It is a little difficult to see the hooks you used in that photograph.
Also noticed, your Enzotech MST-81's, did you use something other than push-pins to mount them? It looks like you used a similar M3 thumb screw as the HR-05 uses.
Hi Aln688, the hooks should have came with the heatsink like in the middle of the picture below.......
Attachment 93348
just place the hook end over the fixing brkt and tighten the nuts from the underside of the board. Should save you some cash :up:
Hello Rob2k, Happy New Year! Shouldn't your handle be Rob2kIX? Just joking.
That's odd, I never had hooks in my package and I never had the same brackets are in your picture, I only had a straight bracket and a slightly bent one at either end, which I couldn't use as it wouldn't go over the screws.
I've already ordered the CNB-S1L, but thanks anyway. When I get it I'm going to try and file off the "arms" and make the heatsink a perfect square, then apply the 3M 8815 thermal tape on the back and stick it to the SB.
Certainly a lot of copper on this board now... :)
Happy New Year to you too .... thought you had an extended Christmas hols :D
Guess they must have removed the hooks for cost saving !, the thermal tape should work well but as the SB chip is smaller than the CNS-S1L it might be worth leaving the legs on at first to test the tape or future use on another board. Your build is looking good :up:
This are 3.8Ghz.
I haven't booted to windows at 1900, I've only runed memtest boot disk, I'm at 1425 becaus I have 4gb, and I can't rum memtest without errors higher than 1600 with 4gb
BIOS 1003, loadline calibration calc error correceted in version 501
at 3.8 e get temps around 63º prime and a high PLL (1,61).
AI OVERCLOCK TUNER ==================== MANUAL
OC FROM CPU LEVEL ==================== AUTO
OC FROM MEMORY LEVEL UP ============== AUTO
FSB FREQUENCY ======================= 475
CPU RATIO SETTING ==================== 08
CPU CONFIGURATION
CPU CLOCK SKEW ====================== AUTO
NB CLOCK SKEW ======================= AUTO
FSB STRAP TO NORTH BRIDGE ============= 400
PCIE FREQUENCY ====================== 100
DRAM FREQUENCY ===================== 1900
DRAM COMAND RATE =================== 2N
DRAM TIMING CONTROL ================= MANUAL
CAS LATENCY ======================== 8
RAS TO CAS DELAY ==================== 7
RAS PRE TIME ======================== 6
RAS ACT TIME ======================= 21
RAS TO RAS DELAY =================== Auto
REF CYCLE TIME ===================== 72
WRITE RECOVERY TIME ================ Auto
READ TO PRE TIME =================== Auto
READ TO WRITE DELAY S/D ============= Auto
WRITE TO READ DELAY S =============== Auto
WRITE TO READ DELAY D =============== Auto
READ TO READ DELAY S ================ Auto
READ TO READ DELAY D ================ Auto
WRITE TO WRITE DELAY S ============== Auto
WRITE TO WRITE DELAY D ============== Auto
WRITE TO PRE DELAY ================== Auto
READ TO PRE DELAY=================== Auto
PRE TO PRE DELAY==================== Auto
ALL PRE TO ACT DELAY================= Auto
ALL PRE TO REF DELAY================= Auto
DRAM STATIC READ CONTROL =========== DISABLED
DRAM DYNAMIC WRITE CONTROL ========= DISABLED
DRAM SKEW CONTROL ================= Auto
AI CLOCK TWISTER =================== AUTO
AI TRANSACTION BOOSTER ============= AUTO
EPU II PHASE CONTROL =============== AUTO
CPU VOLTAGE ====================== 1.36250
LOAD-LINE CALIBRATION ============== ENABLED
CPU PLL VOLTAGEM ================== 1.61
FSB TERMINATION VOLTAGEM ========== 1.33866
CPU GTLVREF 0 ===================== +80
CPU GTLVRED 1 ===================== +40
CPU GTLVRED 2 ===================== +80
CPU GTLVRED 3 ===================== +40
NB GTLVRED ======================= +40
NORTH BRIDGE VOLTAGE ============== 1.51
DRAM VOLTAGEM ==================== 1.90
NB DDRVREF ======================== AUTO
DDR3 CHANNEL A VREF ================ AUTO
DDR3 CHANNEL B VREF ================ AUTO
SOUTH BRIDGE 1.5 VOLTAGE =========== 1.51106
SOUTH BRIDGE 1.05 VOLTAGE ========== 1.06039
CPU SPREAD SPRECTRUM ============== DISABLED
PCIE SPREAD SPECTRUM ============== DISABLED
ADVANCED
CPU CONFIGUTION
CPU RATION SETTING ================= 08
C1E SUPORT ======================== DISABLED
CPU TM FUNCTION =================== DISABLED
MAX CPUID VALUE LIMIT =============== DISABLED
VANDERPOOL TECHNOLOGY ============= ENABLED
EXECUTE DISABLED BIT ================ DISABLED
CORE MULTI- PRECESSING ============== ENABLED
3.6Mhz
- FSB FREQUENCY ======================= 450
- CPU RATIO SETTING ==================== 08
- CPU VOLTAGE ========================= 1.35000
- LOAD-LINE CALIBRATION ================= ENABLED
- CPU PLL VOLTAGEM ===================== 1.56
- FSB TERMINATION VOLTAGEM ============= 1.33866
- DRAM FREQUENCY ====================== 1800
Or 3.2Mhz
- FSB FREQUENCY ======================= 400
- CPU VOLTAGE ======================== 1.32
- LOAD-LINE CALIBRATION ================ ENABLED
- CPU PLL VOLTAGEM ==================== 1.51
- FSB TERMINATION VOLTAGEM ============ 1.20
- NORTH BRIDGE VOLTAGE ================ 1.43
- DRAM FREQUENCY ===================== 1600
- CPU GTLVREF 0 ======================= AUTO
- CPU GTLVRED 1 ======================= AUTO
- CPU GTLVRED 2 ======================= AUTO
- CPU GTLVRED 3 ======================= AUTO
- NB GTLVRED ========================= AUTO
I wish! Christmas goes too quick!
Thanks on the board, I'll post a few photographs after I have everything installed, which should be next Tuesday or Wednesday. I also have to shorten the Panaflo cables, that means getting out my soldering iron and some female pins for the 3-pin plug, then sleeving the cable once done.
I could leave the legs on the Enzotech for now. I read in another forum someone left them on so he could attach a 40mm fan, but I'm aiming for less fans in my system. As a result of using the Noctua NC-U6 Northbridge heatsink, which will be fanless, I upgraded to 86 CFM medium-speed Panaflos front and rear (120x120x38mm) to have more air flowing through the system.
I really like that Noctua U9B CPU heatsink, small and compact, and with the medium-speed Panaflo attached to it (48 CFM), it should perform well. I'm selling the Noctua 92mm fan that came with it.
Just waiting on the Enzotech CNB-S1L, I've already got the Noctua U6. Once the Enzotech arrives I can may file it down, attach the 3M 8815 thermal tape, get the U6 installed and the U9B then the board is ready to be installed in the case.
For case fans, do you use rubber anti-vibration grommets, nylon screws, plastic push-pins, regular steel screws, what exactly? The other item I need to know, is if this board will accept 8GB successfully? Or does my overclock determine how much RAM I can use?
Thanks.
Hi aln688, usually I just use the steel screws that come with the fans but for the front fan on the drive bay I used these which isolate and mount the fan all in one. Others have 8Gb installed which should run fine but the 8Gb will likely control the FSB and CPU overclock - not much use having all that memory and running it below it's rated speed.
