Great work as always, but I'm missing one simple shot of the case, like this:
http://www.hardwaresphere.com/wp-con...e-sideview.jpg
No fancy angles, entire rig in one picture.
Here you have no fancy photo:
http://www.abload.de/img/_dsc07979umb.jpg
Pump simply hangs on a piece of tubing?
I'd be afraid with my Tygon 3/8" 5/8" on Bits 3/8" 5/8"
Only holders keep rez and pump?
Two stock EKWB holders
Nice work, as usual! Can't wait to see the next set of photos (:
Great build.
STX is nice addition.. i quite enjoy mine.
I think the same... stx looks awesome and played awesome :)
Today I had an attack of fear from ...
http://www.abload.de/img/logo_aquatuning_polskaxwzt.jpg
http://www.abload.de/img/phobyalogogdxb.jpg
Two type of fans:
1. Phobya G-Silent 14 1100rpm Red LED
2. Phobya Nano-G 14 Silent Waterproof 1000rpm
http://www.abload.de/img/_dsc08062pcu.jpg
http://www.abload.de/img/_dsc08163qam.jpg
http://www.abload.de/img/_dsc0820wr60.jpg
http://www.abload.de/img/_dsc0821iopq.jpg
http://www.abload.de/img/_dsc0836josq.jpg
http://www.abload.de/img/_dsc0842tom1.jpg
http://www.abload.de/img/_dsc08431q43.jpg
http://www.abload.de/img/_dsc0854pqlo.jpg
http://www.abload.de/img/_dsc0857yqiy.jpg
http://www.abload.de/img/_dsc0807qr59.jpg
http://www.abload.de/img/_dsc0812zo4g.jpg
http://www.abload.de/img/_dsc0808dp67.jpg
http://www.abload.de/img/_dsc0815br0y.jpg
http://www.abload.de/img/_dsc08665rvv.jpg
Love it! That case is amazing. Big fan of fractal design! Any chance you could take a pic in the dark with the new LED fans?
By night - quick shot:
http://www.abload.de/img/_dsc0950o7pl.jpg
Nice...every Malik LC Project look's amaizing...keep the good work as always. Great photo's too
You made wonders with that relatively small case - P193 right?
How do those Phobya fans compare to most favored selection here (AP15)? You have a great camera too if I may observe? Did you intervene with colour saturation to your pics?
...and finally convinced me to buy the Fractal Define XL case! :clap: All the components are sitting here and I will get down to business at the weekend.
One question: could you share that technical drawing you used to cut out the radiator hole? I mean the one that you can see on the screen in this post: http://www.xtremesystems.org/forums/...=1#post4769105
That would be helpful and really speed things up for me at the weekend, especially because it is the first time I will use a dremel on a PC case... and on such a pretty one indeed! :D
Btw: the mesh that you used was Radgard from Bitspower, right?
Hey Malik, I'd really need that drawing which indicates the exact dimensions of the 420 radiator grill. Hope you're stopping by sometime soon...
Edited: Hmm... Found a post of yours over at overclockers.com.au saying that you didn't manage to mount the Bitspower Rad with the radiator you used (it was MagiCool Slim 420 right?) since the holes don't coincide. Too bad, I was planning to combine the two. Will not get around trying til next week, I'll report back whether it was a fit or not.
This build just gets better and better.
Malik, what flow rate are you getting right now? is the single 355 enough to go through all those blocks?
On 100% pump power i have 221 l/h ;)
Those red phobya fans fit very good in this pc :)
I'm baaack with new project ...
project ARC
http://epicstore.com.au/admins-epic-...KWB-Banner.jpg
Objective: Create a simple, aesthetic and efficient project.
What i will use:
Parts:
1. EK Water Blocks EK-Supremacy - Full Nickel
2. EK-FC 570/580 DCII - Acetal+EN (Nickel) with Backplate
3. EK Water Blocks EK-CoolStream RAD XT 240
3. EK Water Blocks EK-CoolStream RAD XTC 280
4. EK Water Blocks EK-RAM Dominator X4 - Acetal+Nickel CSQ
5. EK Water Blocks EK-FB ASUS Max4 Extreme - Acetal+EN (Nickel)
6. EK Water Blocks EK-DDC X-RES 100 CSQ - Acetal
7. EK Water Blocks fittings 12/16 G1/4 black
8. EK Water Blocks fittings CSQ 45 degree
9. EK Water Blocks fittings CSQ 90 degree
10. EK-RAM Dominator Module - Black
11. EK Water Blocks EK-UNI Holder 50/70
12. EK Water Blocks EK-UNI Holder D5
13. EK Water Blocks EK-UNI Holder DDC ADD-ON
Other parts:
1. Tygon 3603 11.1/15.9mm
2. Aqua-Computer Red liquid
3. Corsair AF 120mm oraz 140mm fans
4. Aquaero 5 XT
http://www.abload.de/img/_dsc0005snjbe.jpg
Stay tuned...
Looking forward to see some beautiful pictures from your work Malik!
PS: Especially from that nice Fractal Chassis.
Your break wasn't too long :]
On which case you will work?
Fractal Design Arc Midi
You sir, Inspire me.
I cant wait to see what you do next. Plus your photography is on point. Amazing.
Finally, I'm glad that we'll see the next perfect LC (why again EK?)
Do not make us wait too long :D
ohhh boy
