Originally Posted by neonflx
well i am having a dilemma, i have the Bad Axe 2 board and an ASUS P5N32-E i have enough components to build two systems (- PSU and Ram for one system),
cpu's are E6600 on both
i am currently running the P5N32-E at 475*8 4:5 divider , ram at 1200 and is running great with one issue VMWARE keeps freezing on me unless i disable the onboard lan and use another independent NIC i also have to uninstall nvenetfd.sys and also raid i believe to be faster on the bad axe
i have two wd raptors 36g and two wd sata 160g
on the asus i am running 2 BFG 7600 GT OC on the bad axe i will run one single EVGA 7600 Gt OC (i am not a gamer tho)
i know i can get the bad axe to 3600 without issues, my cpu likes volts so anything over than that i have to mod. i am running one of my cases with a swiftech water kit.
i end up like this after upgrading a few systems for friends over christmas so i will like to sell one system
i am incline to keep the bad axe 2 with the wc kit and corsair dominator 8500 c5d and the raptors
as the asus is based on 680i and maybe not as stable as the intel
any susgestions? and thanks
