Almost there Tyrou:) ..You can do it:toast:
allez les bleus
you make it
You can pass him :) Good luck with the cascade, still waiting for the 4 :D
mine -> :banana:
passing him will be very very hard, my X1900s are not that good (cold bugged), and he is 1700pts ahead of me :D
and, now, let's go for 3D01 action :)
http://img226.imageshack.us/img226/1230/489168bt.png
... and 3D03:
http://img226.imageshack.us/img226/7695/378484io.png
If MMouse gets his Opteron project running you are all doomed... :toast:
Keep on truckin' Tyrou!!!
Daaaamn :)Quote:
Originally Posted by Tyrou
Tweaked or plain run?
a bit tweaked, as always, but nothing really amazing :D
the hwbot team will love those scores... (#1 06, #1 05, #7 03, #2 01) :toast:
Then we need to find 4 pieces of Woodcrest and a Tyan board so we can tell him to be quite :)Quote:
Originally Posted by jrw
And 6x CU tubes for LN2 with that :PQuote:
Originally Posted by NiCKE^
Yepp then we're talking =) Hm quad sli aswell ;)
we'll make sure it doesn't last forever :D
I can make LN2 pots for the 6 x Woodcrests...:P
My cpu is step 4 QHJJ ES 7530A497 from FCG
With air i was stuck to 218 fsb...with a delta 120mm on the HS i went to 228fsb with SS i stuck to 257.2 on 533 mod
http://www.thelab.gr/attachment.php?s=&postid=379326
and 246 on 667 mod
http://www.thelab.gr/attachment.php?s=&postid=379330
Don't look at the Core voltage...i was searcing the setup...:D
The memory was some twinmoss extreme Value rated at 4200 to 4-4-4-12..:(
I will soon have some better memory to play..:D
GoriLLakoS, can you explain or post a link about that 533/677 mod you have mentioned.
i hear some fanboys that are scared :p: haha
I didn't mean a hardmod....sorry if u understand something like that...i mean that in bios you instead of setting ''By SPD'' to memory you set ''Manual''
The 5fth choice is for the divider to 533(4:3) or 667(5:3)....
That's all...:D
the 533 mod is the 4:3
and
the 667mod is the 5:3...
aha, that i thought it's sth special :D
Lol....all this time i was playing in Single channel mode..:(
If you put the mem modules to 1+3 you need 2+4 to be fulfilled too in order to play in Dual Channel....
I was playing in 1+3...lol again...
Here mine. No mods to the Board. I only did the DC fix for SP2.
4ng3ldust / Intel CoreDuo T2600 @ 3148Mhz / Vc 1.50 / FSB 242 / 2x1024MB Crucial Ballistix DDR2-800 @ 403Mhz CL 4-3-3-10 / AIR / 19.390 s
http://www.forumdeluxx.de/gallery/da...71superpi2.jpg
I updated the strartpost.. please notify if i forgot someone :)
could you please add my scores ? like the ones foir the japanese guys ? :)
:banana: +1 :slapass:Quote:
Done Tyrou :D
Thanks mate
