Originally Posted by
freakBYnature
I've discovered why!!! Yeah I truly did! If you set 1.35 from BIOS it will pump out an approx. 0.05~0.1V EXTRA! So the bios settings regarding vcore is wrong! If you want 1.35V you have to set 1.3 or EVEN LOWER! That's why the higher temps, cause it overvolts it on every single setting!
Enable overvolt: ON (which give 0.205V extra)
VCORE: 1.125
Reboot............ ........... ..........
Windows reads: 1.39V!! ;) Which aint logic, cause it should say like 1.33V!!!
I've figured it out... and by doing this, the temps are NORMAL! Like they should be... idle 30c and load like 44~46C!! :) And I even oc'd my Opteron 170 to 2.6GHz on this volt I just wrote... 1.33V from bios ;) SICK! :shocked: :shocked: :shocked: :shocked:
