Yea thats definitely not a good ideaQuote:
how do you know it will be 0550 UPMW?? :confused:Quote:
Originally Posted by situman
I didn't say you were complaining, sorry if u took it that way.
Tank guys had it in stock for a very short time.Quote:
Originally Posted by kenofstephen
Its certainly a strange problem, the reason I think its heat related is because @ 2.9GHz I can finish Super Pi 32M on the weaker core, #1 (core #0 easy) but Super Pi does not generate max heatQuote:
Originally Posted by Mo3bius
using PRIME95 v24.14 small FTTs @ 2.9GHz core #0 can run all day but no matter the Vcore or settings core #1 only runs for 5 ~ 10 mins max :(
Thats why I think my problem is heat related as PRIME95 generates much more heat than Super Pi
Any Ideas anyone :)
What voltage you using for 2.8? J/wQuote:
Originally Posted by alpha0ne
lolz, my opty165 is too good that my Giga's board HTT can't fulfill it!!
300MHz*9 isn't the max. for my OP165 at default voltage with the Giga board.
I need to buy a DFI LanParty to reach higher HTT and find out the max. of my opty165 at default voltage, may be 2.8GHz?? God knows.
For 2.8GHz I am using 1.475 + 102.4 that shows as 1.51Vcore in bios and 1.488Vcore in windoz CPU-ZQuote:
For 2.9GHz I need 1.475 + 104.8 = 1.54Vcore in bios and 1.52Vcore in windoz
I have a 165 CCBWE 0551 UPMW that does 2.8 with Big Typhoon. I still have to tweak it but I feel I can make it stable. Likes juice much more than the mighty 170 0550 UPMW. I need 1.350vx113%. Still burning my BH-5 tho, now I can't get to the 166 divider with 312HTT :(Quote:
Originally Posted by bmac11
//EDIT Forgot to say it has core 0 much weaker, thats what I need to solve (I won't remove IHS)
have you modded the original fan of Big Typhoon??Quote:
Originally Posted by mursaat
Nope it has the stock cooler. Which one should I buy? Thanks :) anyway, I don't think it's a temp problem. It doesn't pass 48ºC priming (well now its winter, we'll see this summer with 40c outside :D )Quote:
//EDIT I can't find Panaflos here in Spain. Someone knows of any webshop that sells it here? thanks!
165 CCBWE 0550 UPMW
300HTT x 9, 2.7 @ Default vCore + 104% VID on SS.
Dual SP2004 stable.
Will not for the life of me boot past 300HTT, 301 hangs before Windows loading screen.
Suggestions?
just wonder how high it can go with default voltage.:confused:Quote:
Finally! My 0550UPMW 165 arrived today!
Packed by a dumbass but I got it up and running. About 20 pins were bent :stick:
2.6GHz dual prime ran for an hour at stock VCore so that was :D
Then the "problems" began. Core 1 is a killer. Ran 20min prime @ 2.8GHz stock voltage. But core 0 craps out at 2.65GHz. Now running dual prime @ 1.52V and 2.8GHz... So far so good. :toast:
BTW, IHS is still on and max temp I've seen is 43°C with watercooling. Not bad, is it?
have you tested the max. HTT of ur board?:confused:Quote:
Originally Posted by Detract
stock is running at 1,300rpm, I got a Delta running at 2,000rpm for summer:p:Quote:
Tried running 310 with an 8x multi, no go :stick: .Quote:
I thought these boards were good up to 400HTT?
Detract, I got the same problem as yours on Giga's board.Quote:
I just bought a DFI nF4-D.......:eek:
I've not tried at default vcore, 'cause I was searching maximum stability, not max frequency for benching.
This shot can show you what the cpu can do.
http://img66.imageshack.us/img66/334...13960ml.th.jpg
ciao :)
I can believe that the cpu core 1 has reached its physical limit, so, even without IHS, it could keep crashing. You can try with extreme cooling, but you can have the cold bug problem with it.Quote:
ciao :)
Any second opinions?Quote:
well not only did i get my 170 0550 umpw (408) in today, along with my DMM, so i should hopefully have it up and running tonight. i think im going to start it out at 2.6 @ stock voltage and go up from there :p
Opteron 165 0551 UPMW
Opteron 165 0551 VPMW
who has these and which is better stepping?
Originally Posted by Red.Sky
I have Opty 165 0551 VPMW, she could stable prime at 2,7G with vcore 1.5V.
taken from another thread:
ok so i just plugged in the 0550, try it at 2.6@1.4v and it fails within a minute
do i need to reinstall anything? reflash my bios? or can i go from one processor to another of the same type?
its running at 2.7@1.5v now
it fails prime within seconds, but i can run superpi and i can bench it (3dmark01, 3dmark03, aquamark 3
any clue?
EDIT: also core 1 fails within a minute running at 2.7g@1.55v in bios
EDIT AGAIN: my pcie card is in the bottom slot, and my ram is in orange. could that be affecting anything
