http://www.mediafire.com/?8hx8f2k332dlpf3
new bios posted over at KC
just on a new after rma, just with a comment code 00 motherboard an AMD7970 dead
anyone knows what is the last version of AI SUITE II for MIVE ? i have one but no digi/vrm on software control
or link to the last ?
thanks in advance
Sergio
Guys my M4E keeps pulling codes too mostly 65 which is CPU right? I think imc pulls this code if ram setup isn't happy, it just doesn't seem to like my g.skill psc rams, the rams and CPU run fine on lower end Asus boards.....
Oddly I have a P8Z68-V PRO that runs great except sometime it pulls a post error for excessive USB current draw detected, system shutting down but even when nothing is in USB it still pulls error .... So two problem Asus motherboards ....
Any news on Z77 range yet?
Whit Gskill an 2133 7-9-7-24 1T 1.65v org: 7-10-10-27 1T 1.65v I can run 1024wpime but nut use it in game/bf3 In game is set 18XX max
3202 bios is to 68Z ?
opdat
The new bios does not look as before, the new can but see several tweaks at all seen
:D 1 more opdata
100p more in 3Dmark06 cpu score test whit 5.3GHZ I7 2600K an old vcore 1.565v whit new bios 1.525v an farst wprime32m old time 4,8xx new 4.6xx
yes:up:
The chip is fine, I run p95 blend 5ghz 1.428vcore 30min on water, that was the max stress the cpu has had on it. I bought it new and didnt own it a week, sold it because of limited multi. Never benched the chip because it is limited to 53x multi. Do you have any other kits of memory to try?
I ran this while talking to Andressergio on MSN, because he was interested in the CPU also.
http://img714.imageshack.us/img714/7342/p95.png
Uploaded with ImageShack.us
Post code 58 is ram related. See if you can boot to bios (with a single slot memory) and change the dram settings like add more vdimm.
uff the look on new bios is horrible letters on bold
i still cant see the dif
Hey thanks for Detective Sergio and you for helping out figure out this problem with the error 58 , man it had us banging are heads , never thought a damn cat hair could knock out part of my chip Oc Nub , you live and learn everyday , chip running great by the way thank again:up:
This was me at first after trying new chip LOL
http://i84.photobucket.com/albums/k7...20pc/Brown.jpg
Picture of pins , inspecting pins
http://i84.photobucket.com/albums/k7...c/DSC00652.jpg
2 x closer picture of pins
http://i84.photobucket.com/albums/k7...c/DSC00656.jpg
10 x closer picture of pins and the culprit of my error codes " thank sergio for finding this critter "
http://i84.photobucket.com/albums/k7.../hairinpin.png
yea you where right it was ram related cuase i was knocked out 3 slot only for was working thanks DumoQuote:
I use xtreme setup
if the GSkill memory you are referring to is what I think it is, then they are BBSE (not PSC) and should clock very well on the M4E.
RMA your board and start fresh, I am sure almost all of your problems have been the board and not all the cpu's that you have binned through.
With this new bios i can't run my memory up to 1333mhz, the board reboot infinitely !
I'm going to try new bios tonight.
