Nice vcore on that one, what ram?
I've got my 2500K (3107B211) at x54 so far (haven't had much time for OC so far, new tests at next week). I think I kept the vcore on 1.6v, just to make it comfortable for myself and raise the multiplier each time I go to BIOS. Motherboard is Gigabyte Z68X-UD3-B3 which doesn't have very good PWM..
About 24/7 clock, it seems to run stable 4.6GHz @ only 1.3V, prime 12h stable + gaming tests.
Maybe someone has the same board and can share some tips about what to adjust and how much to adjust?
2600K
Batch: 3131A765
4.6Ghz 1.34v
TBH I have no idea WTF I'm doing with SB overclocking!
Attachment 120693
thx, RAM 1600 CL 9
now try 1866 CL 9......
http://img707.imageshack.us/img707/4954/53ghv143.jpg
Hi guys!
I left the the hunting for a good 2600K after 8 crappy chips (max X53) and today i bought my third 2500K (I am more lucky with these I had 2X55)
The strange with this third chip is that with PLL overvoltage enable or disable reaches tha same frequency...(X50) is that normal?
With PLL overvoltage enable i think you can reach 5 more multi...right?
5 more multi? who told you that?
That was what i noticed to my P67-UD4...
After a quick search I found that
http://gigabytedaily.blogspot.com/20...67-boards.html
Now I have a MIVE and maybe it is not the same...
PLL can certainly help with stability but in the end it comes down to the chip.
So...that chip is my worst. With more than X50 multi it freezes at windows logo.. and debug led on MIVE shows AA
2500K
Batch# L132B220
Max: X50
Nice run there.
hi i have a new in package i7 2600k bacth L105A823 do you know if it is good o bad ?? thank you vincent
Batch imho doesn't really matter. Just test it and see for your self.
I tested 13 CPUs and i can tell you, there is no rule to judge them
batch L104A617
max multi 54
max clock seems like 5400 :shrug: (can't get anymore in ai, and cannot boot from bios if >5.4 less multi)
max blck: 106.2
http://img5.imageshack.us/img5/3531/696sp32m.png
http://img510.imageshack.us/img510/4...arkvantage.png
anyone know anything about
L134B318?
EDIT:i'll just test it :yepp:
2500K - L129B673 - #1532 - 53x
http://i.imgur.com/uwmGV.jpg
Not sure about absolute max speed, but this is what I can get on air and 2 cores. 5400 is a no go and 53 is max multi.
2500k batch #: 3111B247
s/n: 2L052237A5302
max multi x53
batch: L134B318
max multi: 52 (eew!)
but is low voltage 1.4v 5ghz.. hopefully someone will buy this off of me
25 K @ 5.5 GH
Spi 32 MB
http://img705.imageshack.us/img705/3058/77739139.jpg
L120B308
59x doable on SS
Attachment 121039
I was pretty lucky with sb cpu on my last 2 purchases. On my 4th CPU, I got a almost 5.8ghz cpu, so I though I should buy another one for general use to slow down the degrading of this CPU. In the end, the new cpu I got do better. 5.9ghz is spi32m doable and I will try for 6ghz validation when I get my hands on some LN2
my gosh.. how lucky!
best i have out of 10 2600ks overall was a 54 multi which has degraded to FUBAR.. it can't even hold 3d anymore @ 5400 when it used to be able to :(
got a few chips comming in... 3x2600ks from newegg and one used 2500k batch 3102C224
fingers crossed
hmm
I7 2600K COSTA RICA Bacth 3134B020
fast test whit 1.55v x56,gonna test if it will more a x56,maybe I will put something else on cooling, a water
superpi :rolleyes:
06
http://img842.imageshack.us/img842/8118/cpu3e.png
Cpu: Core i7 2600k
Batch: L046B028
Motherboard: Zotac Z68 AE
Cooler: Coolermaster V10
Clock: 4.5 GHZ
vCore= auto (1,24v runing linX)
http://img705.imageshack.us/img705/3632/21251927.th.png
