Why is it so hard to get Linx stable? I got a 2500K running fine on 5.0Ghz, IntelBurnTest and everything else without a hiccuup. Right now i'm running Linx at 4.6Ghz and I just hope it will be stable. Can anyone explain this staggering difference?
You're going to get a lot of technical reasons but basically, LinX is a B**CH.
PS
And I'm not saying Prime is easy either.
What a lovely forum update. Just compare these two.
№ User CPU name & frequency C / T vCore Motherboard Cooling type Batch # 1. lkozarov Core i7 2500K @ 5500.0MHz 4 / 4 1.584 ASUS P8P67 Pro Single Stage 3048A446 2. newhit Core i7 2600K @ 5407.7MHz 4 / 4 1.692 Gigabyte P67A-UD7 Water L042B076 3. TWK_OCZ Core i7 2500K @ 5341.9MHz 4 / 4 1.608 ASUS P8P67 Pro Water L051B314
Rank | User | Frequency and # cores + threads | vCore | Motherboard | Cooling type | Full Batch #
- lkozarov | Core i7 2500K [4C 4T] @ 5500.0MHz | 1.584 | ASUS P8P67 Pro | Single Stage | 3048A446
- newhit | Core i7 2600K [4C 4T] @ 5407.7MHz | 1.692 | Gigabyte P67A-UD7 | Water | L042B076
- TWK_OCZ | Core i7 2500K [4C 4T] @ 5341.9MHz | 1.608 | ASUS P8P67 Pro | Water | L051B314
Will do it manually, might be done by the end of the next week.
Woa, first time noticed table feature used. Worthy addition from forum upgrade indeed.
thx for the update´s zalbard :up:
Batch 3103B306 solid wall @ 5405Mhz - Ud7 B3 - Single Stage -15C evap. idle temp. - 1.405 Vcore LLC7
http://img89.imageshack.us/img89/208...enshot060o.jpg
My new results, pretty crap considering my RIIIE only needed 1.33v for 4.5ghz. This board is E770
http://img51.imageshack.us/img51/1535/39040853.jpg
Uploaded with ImageShack.us
@xdave: is that on air?
Also, updated! :up:
OK, cool, thanks! I added this info. :)
Nice job, by the way! :up:
ROFL! I apologize for my illiteracy. :(
I hope this is better. And if i did anything wrong please correct me.
Motherboard used: Asus R3E| VCore 1.375
Cooling: H20
Batch:3012B113
http://i53.tinypic.com/5br5ag.png
Lynx is supposed to be running on the 21st loop.
You probably should restart an launch CPUz before anything else so you get a voltage reading. 1.57.1 should be able to show your volts.
1.57.1 still isn't showing voltages.
Sorry for not reading the update.
I will do another run going into the 21+ loop.
You have something interfering with it. Mine works if CPUz is the first thing I start after bootup.
I'm also wondering why so little ram. 2gb on a triple channel system? See rule 3.
My submission with my new chip:
zoson | Core i7 970 [6C 6T] @ 4611.0MHz | 1.521 | ASUS Rampage III Extreme | Water | 3018A860
http://i144.photobucket.com/albums/r...m-100gflop.jpg
100GFlops at just 4.6GHz... *FLEX*
Edit: Pics.
http://i144.photobucket.com/albums/r...85256708-1.jpghttp://i144.photobucket.com/albums/r...h_2e6b80b7.jpg
batch #: 3102C246
http://i.imgur.com/Tsjy8.png
@ zoson
141gflops at only 5100:cool:
Then get with the program, man! :P
my 4.6Ghz LinX stable entry
pet168 | Core i3 540 [2C 4T] @ 4615mhz | 1.440 | ASUS Maximus III GENE| Air | 3039B092
http://img820.imageshack.us/img820/4...600linx.th.jpg
update:
pet168 | Core i3 540 [2C 2T] @ 4937mhz | 1.544 | ASUS Maximus III GENE| Air | 3039B092
http://img31.imageshack.us/img31/159...xstable.th.png
