wow - i thought blank cpu's had gone out with the slot 1/2 !
Not so much with multi-socket enterprise level stuff, it seems. I'm not 100% certain you NEED one to run one of these boards on a single processor, but I know the blanks exist (product code ABBUPCONFIG).
it should look something like this i'd guess.
http://www.itspares.com.au/image/cac...16-120x120.jpg
is ebay article 380277252795 a suitable HS for sossy?
Hey, Tiro ... remember back when we were talking temperature on these things? Well I got jack of seeing a substantial (imho) difference in core temperatures so I cleaned and remounted my heatsinks today.
CPU1: 26 and 31C
CPU2: 32 and 31C
One core (the second last one) was getting up to 47C during the day before. Happier now. :up:
can't wait to get mine ;)
Of course! :cool:
I don't think I've ever taken idle temps on this thing.
Gone up a little now with the evap off (and it's 20:49)
Attachment 109711
A 6k fan? Yep. I have an itty bitty CPU fan from a Pentium 200 on the Northbridge. You wouldn't know it was there the thing is so quiet. I also have two CPU fans from a couple of old Celeron 1.7s (s478) that I've modified to fit the OEM heatsinks, but for some reason they don't show up in the sensor readings.
tiro, what did you do to mount the Cooljag Falcon Mini Chipset Cooler
on your sammy? It looks like I will be building another one. Just need to find heatsinks.
Cool. I would like to see how you did it.
ok here is part 1: http://www.youtube.com/watch?v=YEf6qeBxk9I
& here is part 2: http://www.youtube.com/watch?v=oWlMPARnmLY
I *highly recommend watching with pen & paper in hand :up:
excuse the mono-tone voice :yawn:
Nice job on the vid. I hope to put it to use.
Wow, it is that sensitive to mount pressure? I wouldn't have guessed that.
Question - why did you not use the metal plate that came with the board? I would think it would serve the purpose of the washers, since it has a smaller hole in it.
Nicely done and very nice effect..
What diameter are those fans? 60mm?
