So 249 aircooled and 270 under -90° hummm 21Mhz Not so bad :)Quote:
Originally Posted by boblemagnifique
Great times :woot: interesting bobby.... can you try with any IHS to see if this gap is due to core or pcb temp ? :toast:
No ones bother to check that memory actually set the wall max on certain fsb?
@ stummer ... done ;)
Thanx...;)
Maybe an update will come, have other RAM to test...:D
How much voltage D9 fatbody chips can handle 24/7? Lets compare to DDR1, say old bh5 3.5V, new UTT 3.3V. These? 2.3V, 2.5V? more?
Guys, have any checked your real/actual vcore???
took my multimeter out.. @ 1.5v in bios/actual 1.48v in bios... im measuring only 1.38-1.40v, under light load goes down to 1.35v.... on Auto voltage its at 1.25v
wat are you guys getting?
@Napalm: which measurepoint do you use?
The one oh hicookie give wrong results for me...:rolleyes:
No volts mods stock air.:)
there several points, hicookies is 1 of them but all the points confirm the same voltage.. besides the v regulators there are 2 empty spaces between the 6-in row caps and the v regulators theyr marked like a ZZ<-backward ZQuote:
Originally Posted by stummerwinter
Still on air... :D
http://img116.imageshack.us/img116/5330/179909ve.png
tyrou :D what mem you got...
how high can you go on 3-2-2-8?
Corsair 5400UL -> Fatbody D9
with proper voltage, I can reach ~405MHz 3-2-2-2, but it requires 2.5v at least, and I'm too lazy to turn my trimmer :D
(more seriously, I have to try some cas3 benches)
nice ram tyrou ;)
I tried to find some UL but had no luck. I have read this entire thread but I don't remember seeing that you had put your chip on phase. Are you getting the feel of the setup first?
Originally Posted by Tyrou
Holy :banana::banana::banana::banana:ttt !!! 18k @ air is insane... that completely own ANY FX60 @ same speed...
Now imagine a good bench @ 3.5/3.6ghz LN2 & crossfire @ 9xx/9xx... :eek:
22/23k possible??
@ tyrou..
Great... im now on 394mhz 3-2-2-1 but cant get higher (fsb problem).. im on 2.51v als on 5400ul.. i love this mem
crank up the volts, mine loves 2.6+ :D
runmc: my chip went under phase for testing purpose this afternoon, unfortunately, the mobo was not modded at this time, and was only able to get the 3520Mhz screenie I posted on page 76 (with the 17.xxx SPi)
tomorrow, I'll put it back under -35c, with the mods on :D
Nice runs there Tyrou:toast: You don't have a cold boot problem with your mobo when run with phase?
@runmc....Hows the board so far?:)
I just got a chip that wouldn't past 209FSB :(
@Napalm: maybe we should swith to the problem solving thread...;)
But, look at this:
http://www.xtremesystems.org/forums/...5&postcount=23
UPDATE - got under 19 s - :banana:
No mods!
No tweaks!
18.922 s
CPU: T2600 ES @ 249 MHz x 13 with 1,5 V
Cooling: Zalman 7000B AlCu
RAM: 2 x 512 MB Mushkin D9 PC6400 @ 4-4-3-10 with 2,15 V
nice pi :toast:
some 3d05 under my singlestage, eveything is far from being maxed out...
http://img101.imageshack.us/img101/3499/185514wv.png
Lookin good Tyrou!.....how about some 06 and 03 at those speeds as well?.Quote:
:toast: Kingpin
I'm now benching over 3.4G, so 3D03 and 06 are planned for this afternoon, as soon as I get bored with 05 :D
More 3D benches:
Still on air for the X1900s, cpu under single stage
3D06 :
http://img124.imageshack.us/img124/9656/115044oh.png
3D05:
http://img124.imageshack.us/img124/7058/190513wl.png
And a lil' superpi :
http://img163.imageshack.us/img163/9471/173432in.png
Nice work Tyrou! 1617p to the "untouchable" ;)Quote:
500p/120MHz -> 3800MHz should do it with some more graphics power.
I dream of kicking this AMD fanboy's a**, but Jason is really more skilled than I am, before reaching him, I'd have to pass almost every 3Dmark legend (Kinc, Overklokk, Macci, Kingpin...), that's a lot of work :D
Next weekend, I hope I'll have some time to put the cascade on the cpu, and two single stages on the gpus, there, we'll see how hig it goes :)
