I'm from Hong Kong. The chip is from a local computer shop.
4 instances? I've been doing 2.Quote:
Originally Posted by ivo0613
Is the standard 2 or 4? :confused:
oh... I learned that 2 instances for single core and 4 instances for dual core. Doing so could stress both CPU & memory at the same time.:)Quote:
Originally Posted by keichan82
That's the silliest thing I've ever seen. If you want to stress the CPU and mem, run a blend torture test. 1 instance/core is the standard. If you run 4x with dual-core, than each instance will only load 50%, doesn't help.
Originally Posted by thunderstruck!
When i try to run 2 instances of blend it only picks up on 1 core (50%). Small or Large fft works correct, always 1 per core (100%) Any ideas on what i'm doin wrong? i have affinity set. one P95 is cpu 0 and the other is set for cpu 1.
Originally Posted by situman
There shouldn't be anybody trying to OC above 300htt with anything other than a DFI lanparty. I haven't seen many motherboards that can even come close to the DFI. If those of u complaining about low OC's are not using a lanparty, maybe you should get one. They are absolutely the best OverClocking motherboards on the market today.
Really? I got 321htt with my Sapphire :) And who said I was complaining? My only complaint is my cpu couldn't max out this board since I haven't even touched the chipset and LTD volts yet.
unless you want accurate temperature readings... :(Quote:
Originally Posted by nugzo
Hmmm.. I might have a over-volting problem.. Right now I'm dual priming at ~2.1 with 1.20v. Isn't that kinda low?? I thought this was a more common problem with the expert.
I'll have to solder in some wires tomorrow so I can check the actual readings.
I have the same problem, tried to ask here and in DFI-street without reply...Quote:
I think this is a software issue, so i simply run first the small fft test, then the large fft---> ok this way get lot of time but at least i have 100% accuracy in stess tests
Note: i think i have found the nature of the problem with Prime Blend Test---> it seems that the Blend Test use a LARGE amount of memory (like he is running on both cores) when start: this way all the memory is on core0 and the second core simply don't have enough memory left for running the test.
This not happens with others tests, since the memory is equally balanced between the 2 cores by the software
Just popped the IHS off.. it wasn't so bad... but it didn't help. I placed a temp probe right next to the core and even mounted twice to test contact to the core. The software temps are pretty accurate. The probe confirms about 38-40* idle and about 49-52* under full load.. even with 1.2 vcore.
::vcore and vdimm are normal. Vcore in bios = 1.30v +104% and my multimeter reads 1.35 idle/1.37 load.
I'll take it up over here if anyone wants to reply..
http://www.xtremesystems.org/forums/...ad.php?t=83894
I heard that Asus A8N32-SLI deluxe is as good as Lanparty if not better.Quote:
Am I so lucky then? :eek:
I ran my Opty 146 prime stable @ 333×9 with 2GB OCZ gold at stock chipset voltage. :stick:
DFI SLi-DR btw... Chipset passive cooled by modded Zalman heatsink.
You didn't read it at XS certainly :stick:Quote:
Originally Posted by dickeywang
Hi guys,
I am new to this great forum~Hello!!:woot:
I also got an OP165, which is running @ 300*9 , default voltage on air now.
Idle is about 25-26C, while full-load is around 43-44C, which is a lot hotter than my previous OP146.:mad:
http://www.xtremesystems.org/forums/...1&d=1138635131
LanParty pwns... I was testing HTT's last night and the last HTT i took a validation of was 420 though I was stable up to 440, couldn't get it to boot at 450. :(
http://www.xtremesystems.org/forums/...1&d=1138636435
http://valid.x86-secret.com/show_oc.php?id=68124
My setup
LC Power 550 silent
Dfi Nf4 Ultra-d
Opty 165
Zalman 9500
2*512 Gskill 4800FF
http://img358.imageshack.us/img358/7...28620pd.th.jpg
http://img374.imageshack.us/img374/4...30512qo.th.jpg
Ciao :)
what in the hell have you done with your quicklaunch toolbar, rofl...
Nice clock :toast:Quote:
Originally Posted by Mo3bius
I am having some heat problems with my 170, may be time to flip the lid :)
http://i16.photobucket.com/albums/b2...ne/32M2860.jpg
I already flipped the lid of a 4400+ Toledo with little gain. The cpu was air cooled by a zalman 9500.Quote:
Originally Posted by alpha0ne
Congratulations for your cpu, it's really nice
ciao
That's my main rig's toolbar, it's full because I need all that stuff to run on it :D :DQuote:
Originally Posted by FragTek
This is also my daily use setting :)
ciao
Mo3bius what is the stepping for your 165?
CCBWE 0546MPMW - batch : xxxxxxxxx096
pcb : T
http://www.hostfiles.org/files/20060131115915_pcb.jpg
Ciao :)
Got my second 0550 UPMW on the way, should be here before this weekend.
Also some other fun toys to play with:
http://www.newegg.com/Product/Produc...82E16813999507
http://www.newegg.com/Product/Produc...82E16821104104
Anyways, how do you guys feel about this:
http://casemodgod.com/Reviews-story-2-78.html
First pic down- no harm no foul putting thermal tape directly onto the IHS?
tankguys has 165 CCBWE 0551 upmw and vpmw
/me flips coin
vpmw it is
