You have the same value for both the NB & FSB, try changing 1 or the other. I would try your cpu gtl's. It's harder to start high and figure out problems than to start low and work your way up "ironing out" problems.
Larry
Given ASUS' product life cycles I'm surprised they're still even making BIOSes for the P5Q series.
have mod for the new Bios 2101 (P5Q-E) ?
ftp://ftp.asus.com.tw/pub/ASUS/mb/so...-ASUS-2101.zip
Basically 48bit addressing is just a extension that makes things more efficient on large drives if I remember correctly, I forget the details
Good chipset, lots of quirks. Guess asus are determined to make it the ultimate P45 board.
When I get the time, hopefully tomorrow or the day after.
P5Q-E not have the option to select 1T memory?
Only it stabilizes at 4GHz (475 * 8.5x)
1.43v (LLC Enable)
PLL: 1.58v
GTL # 1: 0.645 x
GTL # 2: 0.645 x
VTT: 1.42v
NB: 1.38v
NB GTL: 0.66x
CPU and NB Skew - 100PS
What's wrong?
470*8.5x 1.440v (LLC Enable)
http://img21.imageshack.us/img21/3601/470passed15.jpg
(Shiiiiiiiiiiiiitt ! )
Your Voltages are way too high! What do you expect? That someone gives you settings, that work? Won't happen, 'cause every CPU and every board is different. For a 45-nm-CPU and 24/7 I wouldn't go higher than:
VCore: VID + 10% (better disable LLC)
VPLL: 1,56 Volt
VTT: 1,30 Volt
VNB: 1,40 Volt
When I see your settings, I take a pity on your CPU... try to lower your voltages.
BIOS-Template for 45-nm-CPUs:
I colour-marked the settings in red, i would categorical fix.Code:Ai Tweaker
Ai Overclock Tuner [Manual]
CPU Ratio Setting []
FSB Frequency []
PCIE Frequency [100]
FSB Strap to North Bridge []
DRAM Frequency [] <--- try not to overclock as far as possible
DRAM Timing Control [Manual]
DRAM CLK Skew on Channel A1 []
DRAM CLK Skew on Channel A2 []
DRAM CLK Skew on Channel B1 []
DRAM CLK Skew on Channel B2 []
1st Information : X-X-X-XX-X-XX-X-X
CAS# Latency [X DRAM Clocks] <--- manufacturers specification
DRAM RAS# to CAS# Delay [X DRAM Clocks] <--- manufacturers specification
DRAM RAS# Precharge [X DRAM Clocks] <--- manufacturers specification
DRAM RAS# Activate to Precha [XX DRAM Clocks] <--- manufacturers specification
RAS# to RAS# Delay [X DRAM Clocks]
Row Refresh Cycle Time [XX DRAM Clocks]
Write Recovery Time [X DRAM Clocks]
Read to Precharge Time [X DRAM Clocks]
2nd Information : X-X-X-X-X-X-X
READ to WRITE Delay (S/D) [X DRAM Clocks]
Write to Read Delay (S) [X DRAM Clocks]
WRITE to READ Delay (D) [X DRAM Clocks]
READ to READ Delay (S) [X DRAM Clocks]
READ to READ Delay (D) [X DRAM Clocks]
WRITE to WRITE Delay (S) [X DRAM Clocks]
WRITE to WRITE Delay (D) [X DRAM Clocks]
3rd Information : XX-X-X-X-X
WRITE to PRE Delay [XX DRAM Clocks]
READ to PRE Delay [X DRAM Clocks]
PRE to PRE Delay [X DRAM Clocks]
ALL PRE to ACT Delay [X DRAM Clocks]
ALL PRE to REF Delay [X DRAM Clocks]
DRAM Static Read Control [Disabled]
DRAM Read Training [Disabled]
MEM. OC Charger [Enabled]
AI Clock Twister [Lighter] <--- the stronger, the better
AI Transaction Booster [Manual]
C/P : A1 A2 A3 A4 | B1 B2 B3 B4
LVL : 13 13 13 13 | 13 13 13 13
Common Performance Level [13] <--- the lower, the better
Pull-In of CHA PH1 [Disabled]
Pull-In of CHA PH2 [Disabled]
Pull-In of CHA PH3 [Disabled]
Pull-In of CHA PH4 [Disabled]
Pull-In of CHB PH1 [Disabled]
Pull-In of CHB PH2 [Disabled]
Pull-In of CHB PH3 [Disabled]
Pull-In of CHB PH4 [Disabled]
******** Please key in numbers directly! ********
CPU Voltage [] <--- personal limit: VID + 10%
CPU GTL Voltage Reference(0/2) []
CPU GTL Voltage Reference(1/3) []
CPU PLL Voltage [] <--- personal limit: 1.52 - 1.56
FSB Termination Voltage [] <--- personal limit: 1.12 - 1.30
DRAM Voltage [] <--- manufacturers specification - 0.08
NB Voltage [] <--- personal limit: 1.12 - 1.40
NB GTL Reference []
SB Voltage [1.10]
PCIE SATA Voltage [1.50]
Load-Line Calibration [Disabled]
CPU Spread Spectrum [Disabled]
PCIE Spread Spectrum [Disabled]
CPU Clock Skew []
NB Clock Skew []
CPU Margin Enhancement []
Advanced > CPU Configuration
C1E Suppport [Enabled]
Max CPUID Value Limit [Disabled]
Intel(R) Virtualization Tech [Enabled]
CPU TM Function [Enabled]
Execute Disable Bit [Enabled]
Intel(R) SpeedStep(TM) Tech [Enabled]
Intel(R) C-STATE Tech [Enabled]
And what's wrong with the screenshot? "Your PC has successfully passed Linpack testing." So your VCore isn't the problem (I really wouldn't enable LLC, especially with this high VCore). Test with Prime95 In-place large FFTs, if the other voltages are correct.
What's the m2005 BIOS :D
Its mad the amount of requests I'm getting for other P5Q Series mBIOSes, so here is what I'm going to do... I'll check out all of the current P5Q Series boards Asus have (which is a crapload) and I will hand pick some boards to add to the list, not all P5Q Series boards will get a mBIOS simply because a vast majority of the P5Q bards Asus have in the lower ranks are utter crap.
The additional boards that made it on to the list are the P5Q Turbo, P5Q Pro Turbo, P5Q SE, and P5Q SE Plus.
Hello, someone is having difficulty to do over, with Q9550 on the P5Q-E ?
[] 's
---edit---
PCI-E Frequency: 100 (101 does not post)
corfa..
@ket when u rls new mBios for P5Q-Deluxe (2005)
New mBIOSes up, check first page.
the P5Q-E has been updated for 2101 too? or continue in 1901?
thanks
This is an interesting thread. I just picked up the Deluxe model and I am getting used to it. If anyone cares to comment, what are the differences/advantages to the modified bios. I currently have bios 2001. If I wanted to try one of these would I have to flash m2005? I assume you can use EZ Flash.
400x9: 3.6GHz
Memory: 5-5-5-12 PL=7
vCore: 1.27
vDimm: 2.00
vNB: 1.34
Looks like it's 2101 according to this link:
http://www.megaupload.com/?d=UTSBQK06
i just can not open the mega link.....faint/../////
thx Ket
I have to admit, the Megaupload CAPTCHAs are particularly brutal to interpret! I've cross-posted it here:
http://rapidshare.com/files/23351461...IOSes.rar.html
