hi there lads, im not an actual RF owner, but i do have its bios modded to my P5E :D bios is RF0410. ok, so straight to the point... i was just wondering how i could set tREF values in bios instead of having to set them with MemSet 3.4 in windows. any clues? i thought that extreme tweaker was the right setting to do the trick, but the other day i proved myself wrong... the strange thing is that when i had my SuperTalent (cheap ass) memory, i allways had tREF at 16383T while on "Stronger" extreme tweaker setting.. but now, with my g.skill set i find that i would only get 3120T when in OS. "strange" :( i thought, "but hey, dont give up!" and so i ended up here...
hope this helps:
Code:Extreme Tweaker
Ai Overclock Tuner : Manual
OC From CPU Level Up : AUTO
CPU Ratio Control : Manual
- Ratio CMOS Setting : 7
FSB Frequency : 458
PCI-E Frequency: 105
DRAM Frequency: DDR2-1100
DRAM Command Rate : 2T
DRAM Timing Control: Manual
CAS# Latency : 5
RAS# to CAS# Delay : 5
RAS# Precharge : 5
RAS# ActivateTime : 15
RAS# to RAS# Delay : Auto
Row Refresh Cycle Time : 50
Write Recovery Time : Auto
Read to Precharge Time : Auto
Read to Write Delay (S/D) : 9
Write to Read Delay (S) : 4
Write to Read Delay (D) : 6
Read to Read Delay (S) : 4
Read to Read Delay (D) : 6
Write to Write Delay (S) : 5
Write to Write Delay (D) : 7
Write to Pre Delay: 14
Read to Pre Delay: 5
Pre to Pre Delay: 1
All Pre to Act Delay 6
All Pre to Ref Delay: 6
DRAM Static Read Control: Enabled
Ai Clock Twister : Stronger
Transaction Booster : Manual
Common Performance Lvl: 7
Pull-In of CHA PH1: Disabled
Pull-In of CHA PH2: Disabled
Pull-In of CHA PH3: Disabled
Pull-In of CHA PH4: Disabled
Pull-In of CHA PH5: Disabled
Pull-In of CHB PH1: Disabled
Pull-In of CHB PH2: Disabled
Pull-In of CHB PH3: Disabled
Pull-In of CHB PH4: Disabled
Pull-In of CHB PH5: Disabled
CPU Voltage : 1.375000
CPU PLL Voltage : 1.5
North Bridge Voltage : 1.51
DRAM Voltage : 2.0
FSB Termination Voltage : 1.36
South Bridge Voltage : 1.10
Loadline Calibration : Disabled
CPU GTL Reference : 0.67
North Bridge GTL Reference : 0.67
DDR2 Channel A REF Voltage : Auto
DDR2 Channel B REF Voltage : Auto
DDR2 Controller REF Voltage : Auto
SB 1.5V Voltage : 1.55
Advanced CPU Configuration
C1E Suppport : Disabled
CPU TM Function : Disabled
Vanderpool Technology : Disabled
Execute Disable Bit : Disabled
Max CPUID Value Limit : Disabled
many thanks in advance for any piece of advice anybody can provide :)
