Guess importing em isn't that cheap.
Well we can change places for a few shopping days :D
U get some CSX and I get more MM towers ;)
Haha, sometimes I ask myself, how come such great stuff are not available in US, oh well!
When are you getting your memory?
Well there is alot of stuff u won't get at germany too like watercooling parts ^^
Could get the dominators tomorrow, depends how much time I have to get to the local store. The CSX could arrive on friday or monday.
Right now i´m running my QX9650 at 450FSB with a multi of x8.5 giving 3825Mhz. I tried to run a multi of x9 to give 4050Mhz and gave a bump on the vcore but i allways have errors in Prime 95 and allways the same core (core 4) just after a few seconds. Any advices what i can do more?
When you get your Diablos, make sure to post some pictures, I love those memory sticks :D
I had to bump my vcore up a little, plus PLL up to 1.60 (bios). NB is @ 1.58 but all temps are kosher. Stable baby. SB is bumped to 1.60 as well. Temps good, no freeze, prime95 and OCCT are good, happy days.
im also at 1.6 PLL, that was the trick to get stability for me.
Long time ago 1.56 PLL was the trick for me
Tried that Slim but no sucess....
Also raised PLL to 1.56v but no sucess again. Core 4 allways fails fater 2 or 3 seconds.
I will try play with GTL refs...
Another thing that is driving me crazy, is Nvidia GeForce drivers, wich one should i use to get the most from my 9800GX2?
I currently use 175.19...
currently running the 177.83 on my gx2 quad
175.12 worked the best for me till now
I'm using the latest 177.83 drivers and have gotten the best out of 3dmark06 and vantage with these. I did shut of Physx for 06, and that seemed to help by about 200 points or so. I should also mention that I'm on Vista 64.
I´ve instaled 177.83 but physx is not working...
In the physx control panel it says NVIDIA physx processor not installed...
Weird... it should be "GeForce PhysX" with the green dot.
http://www.xtremesystems.org/forums/...180445&page=73
M@G!C: First post on the top, have a nice lil pic for you there so you can see what it should look like. Page before this one has a link to the newest GPU driver as well, top post.
Cool, yes that installed part just refers to if you have an independent physx processor like an ageia card. Should be good to go. Flags move in GRID now, woopie? :)
Glad everything is working now :D
I think i might be able to be stable at FSB 462.5 - 1850Mhz that with a multiplier of 8.5 gives 3931Mhz for the CPU :rolleyes:, this only raising the Vcore to 1,36v in BIOS (1,4V real).
But i´m not to confortable to run my $$$$ QX at 1,4V .... :explode2:
1.40 is my max on 45nm
I try to keep it 1.39-1.40 :)
