0543/0546/0550/0551Quote:
:woot: Caught a 165 0550 UPMW from Tank Guys today! These guys rock!
0551 VPMW up on ebay, not going to bother opening it and testing it.
I have a 165 0550 upmw that the second core is not stable @ 2.7 no matter how much or how little voltage I added. (boots into windows at 3ghz with just 1.4 volts. I had a 165 0546spmw that would not dop 2.7 stable no matter what. And I had a 0541rpmw Opteron 170 that would not do well either. My current Opteron 170 0543TPMW only does well to 2.6ghz with 1.475. No matter how much voltage I put on it it will not go any higher. If someone is willing to give up one that does 2.7ghz stable prime for 24hrs I would be very interested!
You forgot 0530 and 0547 ;)Quote:
Originally Posted by Supertim0r
wow.. their inventory must change quickly. I've been checking their site often.. I want a 170 0550 upmw. I don't think I'll ever be happy with the 9x from the 165.. especially if I ever go back to phase.Quote:
Originally Posted by foodfightr
The 165 is OOS now. Didn't get a chance to grab one.:(Quote:
Originally Posted by bmac11
It's hard getting to 3ghz with a 9x multi. A lot of times, the board will limit your overclocks. Most boards can get to 300htt, but a lot more beyond that is a real challenge.
What kind of temps are you getting with your 90?Quote:
Originally Posted by dogsx2
I changed that out with a thermaltake with the 120mm fan and I am now getting around 45C with 1.475 volts w/ full load and 74F ambient temps. Idle I get around 30C. I'm beginning to wonder if my PS can't hold up under load for some reason.
I seem like there must be something wrong when with 3 different cpu's you can't get 2.7 stable. Or, you on a roll of getting poor clockers.Quote:
LOL. Basically ALL steppings MAY be good. Just remember that nothing is guaranteed with this stuff, ever.
Some technician at the plant is in the clean room stirs up a single dust particle which slips into the ubermachine...next thing ya know you have a whole batch of de-uberized chips with da "uber step"!
Hahaa, "de-uberized". Well it figures:slap: :fact:Quote:
Originally Posted by swaaye
Anyway, hopefully tomorrow my 165 0550UPMW will finally arrive. Will be posting some results soon :toast: (I hope :stick: )
i'm happy with my 165 @ 2.7 (TCCD 1:1 2.5-3-3-5)
it's running @ 1.47v... idle 23-24c load 41c with a simple zalman 7000ce led :)
waiting to build a phase change next month to upgrade (something not cold bugged :confused: )
:D I think it's the latter. I'm going to try my 0550 again before I sell it. Maybe reseating it again will make it run better. It does run alot hotter than any of my other steppings though. And it's also my second MB
cdelatte.... I got a nice 170 CCBWE 0550 UPMW that is prime stable at 2.75Ghz w/ 1.44v. Interested?
Originally Posted by cdelong
Check your pm's
How you like your memory? I have mine running those same timings with 2.7v.
Runs nice 1:1, I have lowered it down to 2.8v, but too lazy to update my sig.Quote:
This thread is turning into a FS one.
Kind of like your sig????:stick:Quote:
Originally Posted by thunderstruck!
Sorry dude, but I can't acces the FS forum >100 post. I tried to make it as quiet as possible... Looks like someone read closelyQuote:
My 165 0550 upmw is still running kinda warm.. just resat the heatsink.. applied a little to the heatsink, wiped off, and then only used a small pea sized amount on the cpu.Quote:
Along with software, are these mobo temp probes a lot more accurate than previous ones.. like on my old p4 478? Maybe I should throw on my own temp probe.
my 165 run colder than my 148 @ same voltage :stick:
The odd thing is that the temps barely go up when priming. It goes from about 39-41 idle to 46 under full load with 1.26v. Maybe its the IHS.. but I probably won't remove it since I will resell it when I find a 170 that does 3ghz+
Got my Opteron 165 0550 UPMW 2 days ago. prime95 X 4 stable for 9hr+.:D
http://img233.imageshack.us/img233/5...ultv9hr8vd.jpg
Where did you get your chip from?Quote:
Originally Posted by ivo0613
