One thing I came to love is cabling... Changes the look of any machine completely. Yours is just fabulous.
Well done!
Well done!
Hi I have Curcial Balistix tracer ram and I am getting Overheat issues on my NB and memory so I am looking to get an aftermarket cooler of the ones below which one do you guys recommend? I just upgraded the case to an Antec 900 so I now have decent airflow and my MB temps at 24 idle and 28 load under benchmark or gaming.
Thermalright Passive Cooler:
http://www.svc.com/hr-07duol.html
Thermaltake Passive cooler:
http://www.newegg.com/Product/Produc...82E16835106098
OCZ Cooler:
http://www.newegg.com/Product/Produc...82E16835202003
Corsair Cooler:
http://www.newegg.com/Product/Produc...82E16835704001
Thanks Carter.
Antec Spot Fan...that Corsair cooler rattled my case and pushed less air on high than the Spot on low. Corsair fan's quite a bit louder @ high too.
CoolIT ram cooler
http://www.newegg.com/Product/Produc...82E16835227004
Cant you just get heatsinks for the RAM like the HR-07 shown above? if you have enuf airflow you should be fine with them passive
RIGHT GUYS
I've gone from my Lian Li PC-60 to an Antec 900
Why? because I got the case for free. :)
and thus im going to use this while I plan to mod out my PC-60 Plus
more on that later..
anyway, here are a few pictureees
http://i80.photobucket.com/albums/j1...7/DSC02118.jpg
http://i80.photobucket.com/albums/j1...7/DSC02116.jpg
http://i80.photobucket.com/albums/j1...7/DSC02109.jpg
http://i80.photobucket.com/albums/j1...7/DSC02108.jpg
http://i80.photobucket.com/albums/j1...7/DSC02111.jpg
http://i80.photobucket.com/albums/j1...7/DSC02121.jpg
Looks very nice ;)
I especially like the blue color on the Zalman.
is that antec case any good?
*drool* :D
http://www.abload.de/img/123123123c8c.jpg
Yeahh Tommy Build your TR City :D:D:D:D
Very sexy Tommy. :up:
From your experience is HR-01 Plus more effective than TRUE?
Considering of getting an HR-03 R600 for my red furnace, had it in my hand the other day but didn't score cause of no good 92mm fans at the store, HR-11 coming first :D
Behave!
ey Tommy, here's an addition to your city - http://www.thermalright.com/a_page/m...ct_ifx-10..htm
When will it be out?
did you polish them.. man they shine..... mine are oxidied...
its not much but here are some of the things I modify using a standard fan
http://www.geocities.com/christopher...a/IMG_0341.jpg
http://www.geocities.com/christopher...a/IMG_0343.jpg
http://www.geocities.com/christopher...lviola/pc.jpeg
oh it's already available? can't find it on the egg.:( thought it would fit on the lian-li considering that's way they used as an example.
by the way, we have a similar setup...except i'm using the HR-07 (& not the Duo version)...even in a Lian-Li case
http://i116.photobucket.com/albums/o...n_Rhames16.jpg
http://i116.photobucket.com/albums/o...n_Rhames17.jpg
Well i just finished installing a 5 HHD Bay Cage into My Lian Li PC-7B+ and also modded the side to show off my raptor X :P
http://www.users.on.net/~isaac.miller/case/100_0886.JPG
http://www.users.on.net/~isaac.miller/case/100_0887.JPG
http://www.users.on.net/~isaac.miller/case/100_0888.JPG
