Good to see it has arrived :)
black is always a better choice :)
really nice fractal :)
Some news from work:
1. Aquaero, some mini mods.
http://www.abload.de/img/_dsc90100772.jpg
http://www.abload.de/img/_dsc90074703.jpg
http://www.abload.de/img/_dsc9020u7i8.jpg
Waiting for asus m4e block and second gpu and block. So soon big update.
Look forward to the update and more of your smexy pics :)
Btw Malik, the top rad is the EK Coolstream XT 420 yes?
Malik, what kind of fittings will you be able to fit in the Aquaero block? it seems to tiny for compression ones for me but I could be wrong of course.
No problem with fittings 10/16mm
Aquaero 5 is working :)
http://www.abload.de/img/_dsc9043rgwv.jpg
http://www.abload.de/img/_dsc9079lexh.jpg
Testing SLI:
http://www.abload.de/img/_dsc9103tggb.jpg
http://www.abload.de/img/_dsc9106shko.jpg
http://www.abload.de/img/_dsc9107he1u.jpg
http://www.abload.de/img/_dsc9114ag5a.jpg
http://www.abload.de/img/_dsc91272cuh.jpg
http://www.abload.de/img/_dsc9129wgo4.jpg
Pics, as usual, are the perfect ...
Amazing.
I really like the layout and bundles of PCIE cables,correct only 24pin...
One more thing ... SLI bridge, maybe this version
will be more fit?
Ofc painted matte black.
http://img856.imageshack.us/img856/4700/slibridge.jpg
Try this instead works like a charm, just use some black film to put on it. They come in Glossy, Matte, and different colors.. You can find them on ebay or at MNPCTECH Store
Your system is really looking awesome :clap:
He could just spray paint it. I"ve painted my crossfire ribbon cables white. They look fantastic I think.
that's look amazing malik!!
but where is the waterblock of the M4E?
Fantastic rig and stunning shots as always Malik! :up:
Keep up good work!
for example...
http://i.imgur.com/xZ2J8.jpg
http://i.imgur.com/EDcIl.jpg
The SLI bridge is a different color (in my opinion) to give a break in the uniform color scheme of the whole project. You may not realize it now, but if he had made his sli bridge black you would have looked right over it and nothing(other than the awesome craftsmanship and equipment) would have caught your eye. I think he meant to do it that way. I may be wrong tho.
I like your combo of black, nickel and red
You may have posted this before, but what is the coolant, or dye you are using?
And your build looks SaWeet!!!!
Ok guys some little update:
1. New psu from Antec ( big thanks :) )
http://www.abload.de/img/5h791.jpg
http://www.abload.de/img/687ph.jpg
http://www.abload.de/img/4m7cd.jpg
http://www.abload.de/img/3s76w.jpg
http://www.abload.de/img/2y75t.jpg
http://www.abload.de/img/1473n.jpg
And "this" ... is waiting to be mount ;)
http://www.abload.de/img/_dsc9308hun2.jpg
2. Few new shoots:
http://www.abload.de/img/_dsc9275y7n4.jpg
http://www.abload.de/img/_dsc929917ig.jpg
http://www.abload.de/img/_dsc9301z72i.jpg
http://www.abload.de/img/a21974i.jpg
http://www.abload.de/img/b977p.jpg
http://www.abload.de/img/_dsc929777xd.jpg
http://www.abload.de/img/cp7yr.jpg
And "this" is waiting to be mount:
... and few more parts which are on way to me.
Impressive malik like always. Can't wait to see more.
Loving the blood red dye.
Malik, any chance of changing the Aquaero 's screen "color"?
Parallel connection instead of a serial
looks much better :up:
The flow is also better with this change, right?
Beautiful camera work as usual :up:
