omg I want the MB also to have pci 16x. godd damn :banana::banana::banana::banana:
asus needs to work on its bios. on this newest version i have issues booting and restarting. sometimes it hangs detecting USB devices. other times it takes forever to detect IDE drives. sometimes it says CPU fan error for no apparent reason.
i just put some copper HS near the CPU HSF where it says 'heatsink' on the motherboard and has holes, but no HS there. i am running at 480 w/o orthos errors vs before where it would error. either that or it's cooler (but my room is only 4 F cooler though)
Originally Posted by lowfat
I have the same PSU, same MB and same ram as you
I upped my pcie to 101 and the problem dissapeared.
What video card do you have?
What revisions do you guys have? Which one is better, C1 or C2
Has anyone with p5b mobo and Team Xtreem Micron 3-3-3-8 PC-5300 1GB RAM had any trouble getting high FSB speeds, or ya think there is a FSB limit on my CPU?
Currently im stuck at 457FSB with 9x 8x and even 7x multi with my E6600.
both on a single stage cooler and even -100c cascade not 1 FSB more.
Even with -32c on both the NB and 1.8v not 1 FSB more??????
http://img444.imageshack.us/img444/2385/3yj8.th.jpg
In the past i had a similar issue with a E6400 .
I hit the 457FSb limit then he changed the following setting here in ram
and i got an additional 80MHz at the same 4-4-4-11 timmings.
http://img165.imageshack.us/img165/6...8777bz3.th.jpg
http://img165.imageshack.us/img165/4...8775do3.th.jpg
http://img130.imageshack.us/img130/1...pi1mjo7.th.jpg
http://img66.imageshack.us/img66/133...8secnv1.th.jpg
http://img110.imageshack.us/img110/7...minsbz4.th.jpg
also tried these bios settings recommended here to get more FSB but they didnt help either
http://img171.imageshack.us/img171/116/1hf2.th.jpg
http://img296.imageshack.us/img296/6505/2oj4.th.jpg
http://img171.imageshack.us/img171/3983/3at8.th.jpg
try 4-4-4-12-5-35-4-10-5-13
was using either 6200 turbocache ora 7900GTO. happened with both. Although my memory died, so right now i have nothing.Quote:
Originally Posted by Dazog
Cappie'Quote:
Originally Posted by Cappie
I dont have too much time these days to do further debugs, make sure u are wihthte latest drivers, I now anywhere fro 3-4 slash bars (after a fresh install + bootvis, with all latest drivers (including beta ones)
From what you described regarding he addition of hte ATA making your boot go faster, this leads me to belive that the only PCI device that is actually mainly effected here is hte Jmicron chip.
If defrent combination yield diffrent results, i would say its either a Jmicron bios issues or Jmicron driver issue.
look for latest drivers of Jmicron i'm on 1.17.4
101 at pci freq do not work here after a reboot:(
Thnx C_fun, I haven't even thought of updating that driver, never knew there was a driver needed in the first place, I must have installed it though cuz I ran the checker on the ASUS motherboard cd and I think it installed the jmicron driver from that. So I am probably running a very old driver. Will edit this post if I have some results.
EDIT : It appears I never installed any Jmicron driver and I don't think its necessary cuz look what installing v1.17.04 did,
http://img90.imageshack.us/img90/4098/raidcdromnk5.jpg
now my IDE nec burner is listed as a SCSI device, and its just connected to an IDE channel so giving it raid drivers probably isn't going to help:)
PS : the second SCSI device is normal, thats just the daemontools virtualdrive and thats allways listed as SCSI!
Ya, don't install the JMicron driver - it will jack things up and sometimes force PIO mode on your burners. JMicron is just crap any way you look at it - it's almost worth jumping on the 680i bandwagon.
i got the same results but daemon tools was instaled before i installed the Jmicron drivers by mistake... will my performace be worst now?? with the Jmicron driver installed from the cd i mean
yeah it fux up your cdrom drive, will load up cd's much slower as well once installed, but after deinstall everything seems fine. Don't care really as i'm going raid tomorrow, so whatever is fuxored upzored will be fixed in the process:) And if raid ain't working to fix my boottimes then I will slap a nonformatted IDE harddrive on that IDE channel, get a SATA dvd burner and be done with all this crap:LOL:
after a clean install and using the audigy2 card, i'm getting less than 2 cycles of the windows loading bars every boot :woot:
does anyone now how to set Marwell Youkon to 1000Mbit full duplex ? cant change to anything but 10 100 and auto sense and i get really crappy speeds uploading to my other comp = (
I'm getting very close to ditching this crappy onboard audio!Quote:
Originally Posted by Pyr0
(drivers)
How did you get your IDE drive to get recognized as such, and not as a SCSI drive?Quote:
I have 1 IDE system disc and 1 IDE DVD drive on the Jmicron controller and 2x250 GB SATA II running RAID 0 on Intels controller, but my IDE drives gets identified as SCSI.
anyone have the deluxe board with ocz plat rev 2 ddr2 800? if so, what memory settings do you have?
think its rated for 4-4-4-15 with 2.2V :toast:Quote:
Originally Posted by ingenue007
Wouldn't have a clue man, this board has it quirks as you can see:confused: Minor and time will fix it, probably by the time most people are getting ready to buy new ones:LOL:Quote:
Originally Posted by Malk
When you took that screenshot did you have RAID on any drives?Quote:
Isnt it kinda weird that an IDE drive shows up on the Intel AHCI controller?
I thought the only way to connect IDE drives was through the Jmicron controller?
Or am i missing something?
anyone know how i can clear the saved O.C profile from this board
same here, that 0903 bios kill my qx6700, no more oc with that bios, that is super suks, go back to 0801, its the best for quad.Quote:
Originally Posted by hot_fifty
ouch sorry to hear about your QX6700! ..what were the symptoms ? as i plan to put my Q6600 B3 on P5B DeluxeQuote:
Originally Posted by cupra
Ahem, who says that thats an IDE drive, what you see there is the ahci controller for my two SATA drives. My nec burner is the only thing thats IDE and that only shows up as,Quote:
Primary IDE Channel
Secondary IDE Channel
Standard Dual Channel PCI IDE Controller
I just deleted them for testing purposes to see if Jmicron IDE was causing the slow splash part to windows.
