Multi?Quote:
Originally Posted by Chri$ch
Multi?Quote:
Well, I'm confused once again with this cpu....The cpu's SO erratic, that I don't have any idea what's going on. The other night, I couldn't even get my FSB beyond 215. Today, I tried booting @ 240FSB and there was no problem getting into windows. The cpu pushed beyond 3.4Ghz @ 1.63V on it's initial boot and then upon reboot, it couldn't reach 3ghz :confused: On top of all that, changing cas latency from 5 -> 4 locked my computer up no matter how low the memory speed. This whole rig is really starting to frustrate me and I'm about to give up on yonah if I can't come to a solution in the near future....Quote:
Originally Posted by jmax_oc
with multi 13 is max 258FSB pi stable / with multi 12 267FSB ;)Quote:
Originally Posted by NiCKE^
my rig is up and running too :D
T2600ES QKHK 8 C0 + IHS on it
Aircooling -> XP90
Corsair 5400UL @ 442 4-3-2-2
Aopen 975 non modded
http://img187.imageshack.us/img187/3900/189385ip.png
Air results from a -100C club member? What is the real vcore and is that your FSB limit?
I'm trying to make the Crossfire work, but for now, it's a no-go, single card seems to work, but as soon as I add the second, windows crashes on loading :(
I've got the board this morning, that's why it's still on air, I'm just learning how it works :D actual vcore is ~1.5v, fsb is bench stable at 265MHz, maybe more...
Joli ,ca prevoit, prends en soin de ton combo, veinard :toast:Quote:
Originally Posted by Tyrou
Hmm would be nice in English:)
i presume you tried to install a fresh windows with 2 cards installed?Quote:
anyway, maybe ot, but i have a trouble running 2 videocards @ p4gd1 (or gpl-x), only solution to use 'em both (pcie+pci or pcie+pcie) is to boot up one card disabled in device manager (in safe mode or before restarting computer) and then, when in windows, to enable it.
:toast: Willis and Roadster :toast:
(we'll keep on writing in english, as njkid asked)
caater: I'll try to do it this way, but I think maybe that's cause I still use the stock bios, I'll try to update it
am I the only one here who doesn't give a rats ass about SuperPi? I mean comeon, I play games, not SuperPi, how good are these chips at something that actually matters?
yeah, you're the ONLY one :D
here, we don't USE computers, we BENCH computers :D
Tried with 11? :D Good job guys with the new ones.Quote:
jep, i tried multi 6 - 13 ;)
268FSB = freeze!
:( Too bad.
I'd say, sligthly better or at least equal to A64, and all that with the opportunity to have a passively cooled rig... ;)Quote:
Originally Posted by BrownTown
... until you tear it apart and start benching Superpi again :D
Is it a Dual Core problem? Most of the FX60 not like -90C and highQuote:
Originally Posted by s7e9h3n
fsb my old Fx60 did not over fsb 220 with -90 but it was a good one with
high multi
Yep ......3057 mhz passive cooled......:D running fine
pic
Ok, first day, maybe I get under 19 s...;)
No mods!
No tweaks!
19.250 s
CPU: T2600 ES @ 245 MHz x 13 with 1,5 V
Cooling: Zalman 7000B AlCu
RAM: 2 x 512 MB Syncmax PC6400 @ 4-4-4-12
Can´t stop CPU switching down, use the 1.03beta BIOS. Is there a tool to control the multi?
try this bios (R1.03 / not beta!!!)
http://www.muenster.de/~e30pics/Files/Wica13.zip
Thanx...;)
läuft das da ohne das runtergetakte von allein??Quote:
Can´t update under WXP with this Bios-file, systems chrashes, with the 1.03beta no problem...:(
jop!Quote:
Originally Posted by Staucher
@stummerwinter
seit dem ich R1.03b drauf hatte konnte ich auch nicht mehr in Win flashen, mussu
in Dos machen ;)
ffs use english so everyone understands!
3ghz passive :eek: that's amazing!!
