i'm testing my CABNE 0540 APMW from Computersmsa...
result so far is superpi 1m @ 2300mhz @ 1,344V.
Only my HD got corrupted. pc rebooted during my latest superpi run.
so i'm installing windows again right now :)
148 cabye 0536 xpmw
is this a good one?
new 32M run with my new 2GB OCZ EB DDR 500
http://mitglied.lycos.de/freestylerc...200MHz@32M.JPG
free
Great clocks, nice RAM!! :up:
I ended up with a superpi 1m at 2772,29MHz @ 1,47V with the boxed cooler that came with my FX :) Not to bad i guess...Quote:
Originally Posted by Jack
i tried higher vcore, but temps rose to 45 C during a superpi run...
Next week PhCh results :D
CABNE 0540 APMW
2.88 GHz (9*320) @ 1.47V -> Errors after 20min of Prime 95 Small FFT's, so stable for few hours @ 2.871 GHz (9*319).
I will test more in few times, need time ! only 24h/day :(
just recieved my CABYE 0536GPMW today. yeah, Compumusic packaging had NO padding whatsoever and was packaged in a Western Digiatl box for some reason. The box had 2 straps around it with "Check contents for damage before signing" printed on the straps :lol:
just waiting on my mobo back from RMA now...
freestylercs - what stepping and cooling is that rockin chip on?
That's great ram, sure beats 3-3. You must have a great wc system. Nice rig. I'm glad to see a few of the 144's clocking so good.Quote:
Originally Posted by freestylercs
I just got two of the exact same stepping from EWIZ...... will let you know how it turns out.Quote:
Originally Posted by 5-Clicks
What's your stepping?Quote:
Originally Posted by Pt1t
CABNE0540APMW from computersmsa :DQuote:
Originally Posted by toreide
Thanks. I just finished a burn in at 2900 stock volts for 10 hours. Im gonna see if there are any results yet, however in the past in took about a week before I could start undervolting.Quote:
Originally Posted by wickedld9
njykid, I have a different problem, I have problems running at anything BUT 1:1. Im running 623-3 with TCCD in the orange slots.
Still no XPMWs tested...?
Here's the best spi 1m so far on my CABNE 144.
http://img485.imageshack.us/img485/2580/265945qh.th.jpg
damn !Quote:
Originally Posted by dogsx2
wish my 3 comming 144 will be CABNE :eek:
awesome cpu :clap:
CPU: 0530APMWQuote:
only normal watercooling without Heatspreader, 80mm fan on the rams.
free
Slightly off topic from the thread, but my PC was feeling photogenic tonight so I thought Id drop a pic. This is what houses my Opty...
http://www.xtremesystems.org/forums/...id=39154&stc=1
[QUOTE=LexDiamonds]Slightly off topic from the thread, but my PC was feeling photogenic tonight so I thought Id drop a pic. This is what houses my Opty...
this thing is HUGE ;)
Originally Posted by Supertim0r
The ladies like it...
144 CABNE 0540 APMWQuote:
:D one little 32M Before Work :banana:
http://users.skynet.be/pt1t/144/32M_3010mhz.PNG
OT:
Lexdiamonds: that's the best PC in the world, woot:)
Are you sure? Look at this screenie from G.S Technician on the G.Skill 2GBZX DDR400 2-3-2-5 Test thread.Quote:
Originally Posted by dinos22
http://premium1.uploadit.org/gskill/...est_200_01.JPG
"Wried" indeed.
Thats good to see, I've got a 144 cabne on the way of 0540 batch. Nice to see they are still reaching 3ghz. Problem I have now it weather to keep and use the 144 cabne with it's 9x multiplier as I don't think my ram will reach much higher than 310htt speeds. I also have a 148 cabye which will do 3ghz at 1.65v 1:1 with my ram at 300htt.Quote:
My thinking is to sell the 144 and keep the 148 as it makes life easier with the 11x multiplier.
Nick
I got a CABYE 0536 GPMW from ewiz.
This ihs is a tough nut to crack. My venice was much easier to de-cloth. Has anyone else noticed this?
You can run a divider with no penalty unless your mobo doesn't wan't to work with divivers as some peeps have experienced.Quote:
Originally Posted by Nem
