If you can find a couple of bolts with the correct thread beween 25 and 30mm long then the job should be very easy.Quote:
Originally Posted by JudgeC
When mounting the heatsink, make sure the gap between each of the two aluminium brackets and the heat sink is equal, or the processor core wont be covered entirely by the copper in the heatsink. This isnt as easy as it sounds, since the power supply cables and speed setting jumpers tend to push the heatsink to one side, leading to a ofsett mounting of the heatsink and the core being coverd partly by aluminium.
The center center clip/bracket has to be fipped upside down, I removed the fan assembly to make this easier. The problem then, is that the center clip/bracket isn't designed to be used upside down. In correct orrientation the load is placed through the rounded \/ bottom edge of the _!\/!_ clip, so the relative tightness of the two fastening bolts is not too important. However once the clip is upside down the load of the bolts is taken in two places (each side of the heat sink instead of one place in the center of the heatsink.)
I counted carefully the number of turns on each bolt while tightening, to make sure they were both turned the same number of times. Once the heatsink began to grip the processor core, I made small twisting movements on the heatsink to see which side of the heatsink was gripping the core most. Then I made small adjustments on the bolts until the heatsink seemed to rotate about it's centre when twisting. Then I finished tightening with the same number of turns on each bolt.
Hope this helps.
