Thx. :)
It's a Chieftec BH-01B-B-SL.
yes, i looked like some sort of a Chief. midi tower:)
Here is another picture:
http://i223.photobucket.com/albums/d...6190001aw9.jpg
Chieftec cases are pretty nice, never seen that one before though, looks simple but classy I like it.
How is the quality build of chieftec cases, how does it compare to Silverstone and Lian Li?
Here's my brand new Antec Nine Hundred... Temps are at mid 30's with 120s on medium and 200 on high. My gfx temp dropped of 10°C by changing my case from my old Foxconn TLA570A with a 80 intake and a 92 at the back...
http://img.photobucket.com/albums/v2...3/DSC00161.jpg
http://img.photobucket.com/albums/v2...3/DSC00176.jpg
I got no pic of the inside without the window, didn't think about it :shrug:
that's some messed up cable management in an Nine Hundred...:D
very neat and tidy, good work QS :up:
i like the exhaust green fan :)
Happy about your Be Quiet??? mine died out on me 4 month after buying it....I'm now running an Enermax Infinty 720 and still waiting for the RMA on the Be Quiet (3 months and running:mad: )
you could take out one of the DVD drives and shove the wires into the drive bays.
also you could move the fans up a slot and put the DVD in the second slot, shove wires under the bottom HDD bay and shove wires above the DVD drive.
also get some wire ties and tie down the wires away from the fans. also try to route any wires you can away from the middle of the case. and lastly you can buy a fan for the side mount but seeing where you keep your PC it may end up not working that great. also make sure your heatsinks and fans are clean
deepsilver, wich cpu cooler do u have?
is it Thermalright XP-120?
Mine
Thanks.
very nice immortality
one question, how hot is your processor @ 3.97Ghz :O
i got my e6600 on 3.61Ghz with 1.56V
and its idle temp is around 37'c
