Great triple SLI 480s result Boadar! :up:
Congrats on the gold cup 3DM03 Bodar, well done man !!
Are those TEK9 FAT GPU pots you used there?
Thanks so much Nick and Linuxfan!! :) I did a test once with 4 gtx 480's on air and a 5700mhz cpu clock.. It was also decent.. about 176k.. Maybe there is a 4-way sli gpu frequency combined with a 6200mhz+ that may be good as well.. Or just bump the cpu up to 6400mhz and use 3 of these on ln2 at below 1100mhz.. :D Maybe 1050 might be good.. I dont think anyone is going to beat Nicks 217k score though. that's really awesome!! :D
Thanks Brolloks for all the help on the IOH stuff!! Yeah! tek 9 slim.. There's alot of insulation tape around them.. Makes it look bigger I guess.
i think the base clocks of the 480s are 33mhz i'm not sure..when we were benching 3 480s...we got weird results.... congrats with results...what bios was used for 3d?
nichshih is back!!! nick hows the new kp pot? :D
The bios I used was 704.. I think it's improved with the newer 3d bios.. Maybe I'll try that soon!! Thanks Hondacity!! :D
Thank you for your reply!!
In Japan, Ist delivery lot are rev2, 2nd delivery are rev1.
So I guess rev2 has any problem, now change there rev to rev1.
But as your info, rev 2 is beter than rev1.
I checked some HWBot ranking, SF3D's REX3 is rev1., other top ranker used rev2.
So rev1 & rev2 does not have many changes・・・・・?
Awesome score Bodar!!
Guys please dont trust cpu-z with these boards it isnt configured to read them properly, incorrect vcore and display.
nick
is this what you have?
http://i24.photobucket.com/albums/c5...5/P1030258.jpg
http://i24.photobucket.com/albums/c5...5/P1030256.jpg
Are you talking about cb with the mobo.. If so, I tested an i7 980x yesterday and the mobo shut off at -110c :( Put my favorite chip in and I'm rockin for a few hours straight at -185c :D
I'm pretty sure I have one of the first retails as well.. Hey Nick.. Does the NB pot really help alot on the SR-2? Max clocks on vantage without it have been about 5400mhz so far with two x5680's..
ya , my good R3E all 1.04G
Chill Coldbug always make the offset voltage having some problem
Something like u set 1.7v in BIOS , but u only get 1.5~1.6v
and Some Chill Coldbug will make ur CPU coldbug moving .....
U can replace the mobo with ASUS , if u have such mobo with defective chill chip :up:
If i use only one VGA Card and CPU Water Cooling
which board give me high BCLK
Gigabyte X58A-UD7 or Asus Rampage III Extreme ?
I checkd my rev1 REX3(retail products ver) BCLK limit on air.
The mobo PCB rev is 1.04G, production month is 2010/06.
http://psycho999.blog38.fc2.com/blog-entry-310.html
BCLK=243.8MHz, QPI≒4400MHz
mobo cooling is only stock cooler.
I think rev1 is not so bad.
That's some nice BCLK with high QPI . :D
Did you test highest spi32m BCLK ???
I am very sorry, it just tested only high QPI BCLK limit.
For your reference, my 980X SuperPI 32m result.
http://hwbot.org/community/submissio...in_21sec_641ms
QPI≒4000MHz, BCLK≒180MHz.
It's not my ACE chip, just test new chip internal clock.
